Knock
Old Jan 18, 2003 | 06:12 PM
Ford 2002's Avatar
Ford 2002
Question Knock
Today a noise started in my 7.3 Diesel.
As I throttle up ever so easy I get this knocking sound. As you gain rpm it goes away. If you throttle up fast no noise.
It sounds like when I have in the past sprayed starting fluid in a gas engine. Its very light knock but its there.
2002 7.3
7500 miles
Old Nov 4, 2008 | 10:06 PM
tim_wing's Avatar
tim_wing
Ever find out what it was??? I think I have the same problem
Old Nov 5, 2008 | 11:52 AM
clintbonnie's Avatar
clintbonnie
Welcome to the forum.. Give us some more info on the knock on your 99. Does the engine have a long lead injector on #8?.. Mine was making weird knocking, crackling noises and it turned out to be a bad #8 injector.. Ford has a modified injector for a fix for #8... or..
maybe you got some bad fuel.
Try sending a private message to Ford 2002.. (since it was an old post)
Old Nov 5, 2008 | 09:18 PM
tim_wing's Avatar
tim_wing
KNOCK in 2003 F-250 7.3L
Its a 2003 with the 7.3L 4x4 102K miles I purchased the truck on eBay and sold my 99 because it had 200K miles (nothing wrong with it) just wanted to upgrade when the truck pulled up I noticed it right away it sounds like a normal 7.3 but just a little louder than my 99 and any of my co workers 7.3 fords (5 others) has good power, no smoke other than the edge programmer i've got a straight pipe 4" turbo back, intake, etc. i'm real meticulous i've ran stanadyne, tried #1 & #2 diesel, i've used every kind of diesel clean you can imagine thinking it was a clogged injector obviously changed fuel filter, added 2 qts power punch to the last 2 oil changes and nothing has changed the noisy engine, havent checked for air in fuel or pulled the valve cover to see if I have an LL injector on #8.... think its a possability for either?
Old Nov 5, 2008 | 09:49 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Good god, way to bring up a thread from back when i was in middle-school!
Old Nov 5, 2008 | 09:51 PM
Fordbronco69's Avatar
Fordbronco69
Infidel
wow wing...u pulled up one old thread for sure! welcome to a great place.
First thing I'de do it to check that #8 for LL, I know how jacked up the drivers side is with the harness and what not in the way, but if you know wats in there then you can draw a sharper image to the problem.
Take the oil fill cap off and let it sit in the tub....does it wanna jump out or does it ruffle a little bit? Also about how much white comes outa the oil fill tube with the oil fill cap off?
Old Nov 6, 2008 | 04:06 PM
clintbonnie
Just curious ... can you explain the above in more detail.. are you referring to the smoke jumping and ruffling ?
Old Nov 6, 2008 | 07:12 PM
tim_wing's Avatar
tim_wing
Whats this supposed to do?? Maybe some more information???
Old Nov 6, 2008 | 07:21 PM
Orezona's Avatar
Orezona
Nope, 5 years later he is still wondering....
J/K man. Way to use the damn Search Button. And welcome to FTE.
Kris was in Middle-School
Old Nov 6, 2008 | 08:06 PM
jdecker88's Avatar
jdecker88
He was just dreaming of a 7.3L then
