help identifing my engine
Old Feb 9, 2010 | 05:15 PM
xdroogx's Avatar
xdroogx
ok so how could i find out for sure what my engine is from the
5.8/351M, 6.6/400, 351 Cleveland
i belive i got the 400 on it but the guy who sold it to me said it was the 351 so??? help? ha thnx
Old Feb 9, 2010 | 05:40 PM
Furyus1's Avatar
Furyus1
Assuming it has the original valve covers, is there an emissions tag stuck to the drivers-side cover? That should tell you the engine family/size.
Old Feb 9, 2010 | 06:24 PM
zaaac's Avatar
zaaac
There was no emissions tag on mine so I put the #1 cylinder at TDC and stuck a welding rod in the spark plug hole until it touched the piston and marked it. Turned crank 180* and re-measured. The difference in measurements was slightly more the 4" so I have a 400. Cleveland's have a "2" or "4" cast on the corner of the head and the gasket surface at the front of the intake manifold is nearly level with the thermostat housing gasket surface. Not likely you have a Cleveland.
Old Feb 9, 2010 | 06:56 PM
tinaheel's Avatar
tinaheel
one way is to pull the oil pan an look at the crank an if you see a m5 mark on the counter weight its a 400
Old Feb 17, 2010 | 09:44 PM
1980 Ford F-250's Avatar
1980 Ford F-250
I dont mean to hijak your thread, but what if there is only a 5 mark on the crank?
Old Feb 20, 2010 | 01:50 AM
mustang81's Avatar
mustang81
5M,5MA or 5MAB. Only a 5 ? Should be a 400 crank but i'm not sure.
Old Feb 25, 2010 | 07:59 PM
BDawg171's Avatar
BDawg171
How exactly do you do that? Do you put a wrench on something like the crank pully and rotate it manually? How do you know top dead center of #1 cylinder? Watch your welding rod till it does not push up any higher, then measure and turn 180*?
Old Feb 25, 2010 | 08:12 PM
zaaac's Avatar
zaaac
I set the timing marks on the dampener to 0 degrees and then measured with the rod. Then I made marks on the crank pulley so I could more easily tell when I rotated 180 degrees and re-measured. Yes, I rotated the engine manually with a strong arm. I had all the plugs out at the time so it turned over easy. Not sure how easily it would turn with only one plug out.
Old Feb 28, 2010 | 08:03 AM
mustang81's Avatar
mustang81
Top dead center(tdc) is when the piston reach the top of the cylinder. You will need a 15/16 socket with a small extention. Mesure the distance between tdc and bdc(botom dead center) Should be close to 4" for a 400 and 3.5" for a 351m. This mesure is call the stroke.
broford1
16
Jul 28, 2011 05:27 PM
DESTROYER2B
Mar 30, 2011 04:30 PM
jasond5150
May 8, 2005 04:56 PM
DogFuzz
Aug 3, 2003 10:07 PM
Billy Freeman
Jan 14, 2003 03:23 PM
