Sponsored by: Real Truck
HELP ME!!! NO BRAKE LIGHTS!!!!
Old Feb 9, 2010 | 01:56 PM
twall_SD250's Avatar
twall_SD250
i hope someone can help me out here i have a 2001 f250 with a 5.4l and i have no brake lights all of a sudden. i checked the fuse and it was blown so i went and put a new fuse in, with in 3 seconds the new fuse blew and i didnt even touch the break pedal yet. does anyone know what might be the problem, i am thinking there is a short ...a broken wire somewhere between the fuse panel under the dash and the the tail lights. does anyone know a easy way to troubleshoot this problem..let me also add that i do have tail lights,blinkers, backup lighs and hazards. i hope someone can shed some light on this problem for me and thanks to whoever can help me out
Old Feb 9, 2010 | 02:06 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Prob is prob a shorted wire in your trailer brake connector. You gotta actually take it apart to find it. Most likely in the 7 pin plug, but COULD be in the 4 pin one.
Old Feb 9, 2010 | 02:14 PM
89CrewCab's Avatar
89CrewCab
I had this exact same problem. I took it to the dealer to have the recall done for the cruise control/steering colum fire issue. The recall also took care of the brake light issue. Be sure tomention your brakes light work. I'll bet you cruise control does not work, either.
Old Feb 9, 2010 | 02:23 PM
twall_SD250
its not the cruise control problem i had that recall fixed a few years ago.. the 7 pin plug for the trailer brake is connected inline with the brake lights. i was lookng a a wire diagram in my repair book and i didnt see that i only saw that in the excursions
Old Feb 9, 2010 | 02:57 PM
dchamberlain's Avatar
dchamberlain
The circuits to the trailer connector are relayed and fused separately. A short at the 7-pin plug will blow the appropriate trailer connector fuse, but can't affect the trucks brake light fuse.
Old Feb 9, 2010 | 02:59 PM
twall_SD250
can it be the brake pedal switch..anyone have any ideas
Old Feb 9, 2010 | 03:03 PM
Blind1's Avatar
Blind1
I'm assuming you don't have a trailer connected to your truck when this is happening. I had a similiar issue a while back, and it was due to a bare wire shorting out on the trailer causing the fuse in the truck to blow. Just a thought.
Old Feb 9, 2010 | 03:13 PM
twall_SD250
no trailer connected..im thinking theres got to be a broken wire and its shorting out against another wire or a peice of metal because everytime i put a new fuse in it blows within 5 seconds andim not even touching the break pedal
jerrysrios
Electrical Systems/Wiring
91
Feb 18, 2025 03:12 PM
BTclassics
56
May 9, 2017 09:51 PM
Wally Williams
Feb 3, 2017 08:52 PM
Lt340
Sep 21, 2015 09:09 PM
windsor94
1983 - 2012 Ranger & B-Series
Jul 21, 2009 02:25 PM
