Any 6637 Modders..help?
Old Feb 9, 2010 | 07:56 AM
brownie83's Avatar
brownie83
hey guys...
i just did the 6637 mod. i never had a stock air box, the PO had a cheapo AZ filter on it. i just have one problem...it seems like the inside of the hood is hitting the filter. is this common? i used a piece of 4" ehaust to couple the tube to the filter. i just cant get it any lower. seems to run WAY better now that it is breathing with out asthma. thanks for any assistance
chris
Old Feb 9, 2010 | 08:15 AM
DieselCamper01's Avatar
DieselCamper01
It seems to vary somewhat from truck to truck. Mine was hitting for about 2 1/2 years until we cut the back part of my airbox out recently. Now it drops down away from the hood. I would not worry about it. You are all good if you want to leave it that way.
Old Feb 9, 2010 | 08:25 AM
brownie83's Avatar
brownie83
thanks for the quick response...i didnt want to ruin the filter or lose air flow...thanks again
Old Feb 9, 2010 | 08:45 AM
robs01f250's Avatar
robs01f250
it will be fine, mine rubbed at first, but its nothing that a dremmel tool cant take care of
Old Feb 9, 2010 | 08:54 AM
Justin03PSD's Avatar
Justin03PSD
Originally Posted by brownie83
hey guys...
chris
My hood also hit the filter, I had to do a little cutting:
https://www.ford-trucks.com/forums/8...i-install.html
Old Feb 9, 2010 | 09:05 AM
brownie83's Avatar
brownie83
i read the info, but could see the pics. thanks a lot for the help.....
Old Feb 9, 2010 | 09:06 AM
superduty4x4's Avatar
superduty4x4
I got rid of the stock lower airbox/battery tray altogether and installed a passenger side battery tray on the driver's side. I had to re-drill some holes to make it work, but it works great and looks factory. No more filter rubbing/hitting the hood.
Old Feb 9, 2010 | 09:08 AM
guitarpicr's Avatar
guitarpicr
Had to cut the oe filter box also with dremel.
Old Feb 9, 2010 | 10:58 AM
DieselCamper01
We used a sawzall on mine...hehe
Old Feb 9, 2010 | 11:08 AM
rat49f6's Avatar
rat49f6
U can also use a e99 battery tray... on the e99 the battery' tray and air box are seperate
Old Feb 9, 2010 | 11:36 AM
maevans's Avatar
maevans
Another reason the e99's are more better, Right Jim
Old Feb 9, 2010 | 12:21 PM
superduty4x4
My early bird had the late model intake update on it so I didn't have that option.
Old Feb 9, 2010 | 02:36 PM
Izzy351's Avatar
Izzy351
This guy didn't compare the stock filter setup to the 6637 (Tymar = 6637), but you can see how it compared to an open tube and an aFe on the dyno:
Ok I ran the dyno today with the Tymar, AFE, and open element. Wanted to know for myself what was what so here are the specs:
3 runs with the tymar netted:
1st run on #2=413.7rwhp
2nd run on No2=481.1rwhp
3rd run on No2=481.3rwhp
3 runs with AFE stage2 netted:
1st run on #2=407.0rwhp
2nd run on No2=473.1rwhp
3rd run on No2=472.9rwhp
3 runs with open element netted:
1st run on #2=424.9rwhp
2nd run on No2=493.1rwhp
3rd run on No2=492.3rwhp
Old Feb 9, 2010 | 03:37 PM
krejci.mike's Avatar
krejci.mike
My hood hits the filter, been like that for a few months. Nothing wrong with it yet
Old Feb 9, 2010 | 03:39 PM
brian42's Avatar
brian42
Veteran: Navy
I had to use my Dremel and hack up the intake box/battery tray. Once the filter sat lower I rotated the intake tube elbow just a little bit up and now it sits nice and snug so I don't have to worry about it bouncing around when I'm off-roading.
