95' 302 8MPG running cold??
Old Jan 18, 2003 | 04:25 PM
Duderoy's Avatar
Duderoy
Help!!!
I have a 95' F150 SC 4X4 with 5.0L. I am only getting about 8 MPG city. My question is the temperature. It only warms up to the letter n in " normal" on temperature gage. It had the factory thermostat ( 192 ) in it and I replaced it with 197 degree one thinking that was the problem. Position on temp gage did not change. On all my other gages the needle is dead center of gage when normal. The letter n is barely in safe zone on the cool side. Could the gage or temp. sensor be bad causing over choking and if so how do i check it. Thanks for any feedback at all.
Old Jan 19, 2003 | 07:20 PM
fastf150's Avatar
fastf150
as far as running on the "n" in normal, my f 150 with the 302 runs at the same temp. I think this is because mine has an auxiliary trans cooler. The trans temp will affect the engine temp alo, and unless you are doing some decent towing, my bet is your engine will not ever get very warm at all. That being said, i only get about 8-10 mpg when i am doing alot of starting and stopping (which is normal). If you want to let your engine run at a higher temp, try installing an electric fan with a built in t/stat in place of your mech fan. And set the op. temp at whatever you want it to be.
Old Jan 19, 2003 | 07:42 PM
HippieCustoms's Avatar
HippieCustoms
Ok I hope this helps.... I installed an air/fuel ratio gauge in my truck. It let me do a few things. I can adjust my fuel pressure regulator to richen or lean full throttle runs, and monitor the change, and I can watch when the truck goes into closed loop. the gauge just looses it's mind and jumps all over the place. At first, it was very distracting, but after I got used to it, I was able to use it to taylor my driving habits. Watching when I gave it more gas then I should because it would drop into open loop and go rich. My point is, if you install an air/fuel ratio gauge, it won't solve any problems, but will help diagnos and can be helpfull long term. All of that said....I have a few ?'s. Does the heater blow hot? Are the spark plugs burning very black? Can you always hear the fan, or can you hear the fan come in and out ? I only ask so we can try to get enough data to help.... Good luck, Hippie.
Old Jan 19, 2003 | 08:21 PM
Duderoy's Avatar
Duderoy
the fuel ratio gage is interesting. As far as the other stuff:
Heater blows very hot,
Plugs look clean and white.
and I don't think I've ever heard the fan kick in yet I've only owned the vehicle for about 2000 miles now,
but hears a question***
I've been reading up on performance chips but none of them seem to target fuel mileage just power and my wheels are mainly just transportation and looks--not for pulling. Some say you may gain increase MPG.. May being the key word. I'm going to start simple with a K&N filter and a chip if I can figure them all out. Hope this gives you more details and thanks. Oh ya, as far as I know the truck is all stock.
Old Jan 19, 2003 | 08:24 PM
HippieCustoms
Well it sounds like you have the same truck that I started with, and mine got way better mpg. I actully got 16 on the highway before I started all that I did. Ok so how about tire size? Are they stock (small)?
Old Jan 19, 2003 | 08:37 PM
Duderoy's Avatar
Duderoy
Tires= Roadmaster 30X9.5--R15LT.
Seem to be a good mud tire. Also how do I tell what transmission and gears I have. The trans. is auto w/OD and the OD kick-out on the shifter.
Old Jan 19, 2003 | 08:41 PM
HippieCustoms
Trans is prob an AODE, that's what is in mine. As for gears, could be 3.31 or 3.55. Check the tag on the diff. It will say. But the tires arn't helping you. Have you fixed your speedo? or is it still off alittle because of the taller tires? If it is off, you are actually traveling farther than the speedo says, so mpg is not acurate.
Still just probing for info. Hope to help soon. lol
Old Jan 19, 2003 | 08:55 PM
cek181's Avatar
cek181
my trucks getting about 11 mpg right now on the highway and about 9 around town. it was getting 7-8 before i changed the fuel filter. im running 3.31 gears and 31x10.50 tires. i haven't adjusted my speedometer since putting on the bigger tires so i still have to do that. my next thing to check is my exhaust because its all stock, and i have been noticing a loss of power going along with the loss in gas mileage so possibly the kitties are clogged up. quickest and cheapest things to replace are the pcv valve, and fuel and air filters. hippie, im curious- waht kind of gas mileage does your truck get right now the way it is?
Old Jan 19, 2003 | 09:00 PM
HippieCustoms
Right now, I am getting 11.5 to 12 around town and 13.5 on the highway. I was very proud, but it will take al ong time at that to make up for the cost of all that I did to make it get there. lol.
And that is with my speedo dead on the money. I have had two different hand held gps units that read speed, and they were both within 1 mph of my speedo at 45, 55, and 65.
Old Jan 20, 2003 | 09:07 PM
Duderoy's Avatar
Duderoy
hippie,
How did you adjust your speedo?? I can use a stop watch, but
I don't know what to do if it is off.
Old Jan 20, 2003 | 10:39 PM
HippieCustoms
What year is your truck? If it has a digital odometer, you can adjust it easy. Search the forums for speedo calibration. The instructions are here. Hippie.
