Slip yoke movement
Old Feb 8, 2010 | 07:57 PM
Bruce Jack's Avatar
Bruce Jack
Slip yoke movement
I have a E250 ford van with a 4.6 V8 and a 4 speed automatic.
Does anyone know how much movement should be between the slip yoke on the drive shaft and the tail stock (extension housing) bushing.
I seem to have a lot of movement.
Thanks,
Bruce
Old Feb 10, 2010 | 10:19 AM
Jeff396's Avatar
Jeff396
I have a '97 F350 with the E04D trans that I have the same question about. I'm chasing down a vibration. I haven't measured the amount but I would guess 2 mm. It's enough to make a clunking sound when pushing and pulling on it. That can't be normal. I'll post another question so hopefully one of us will get an answer.
Jeff
Old Mar 4, 2010 | 12:28 PM
Jeff396's Avatar
Jeff396
I hope you still have your ears on. I did get my vibration fixed. I replaced the rear tail house bushing and the resulting play when pushed up and down and back and forth is a fraction of what it was. You don't get that clunking sound anymore as with the old one. Now you can see it move a hair but barely. Also, the new bushing came with some grooves cut into it like some main bearings have in a motor. It looks to be a much better design than the original. With the old one, after I removed it from the trans, I was able to twist it a good bit when I slid it over the driveshaft yoke. It was done! Anyways, it cost me about $25 for parts and a couple quarts of fluid and about four hours of time and viola......it's done!
Hope this helps! There seemed to be a lot of people having this problem but I only found one thread where the guy came back and posted his results. Good luck!
Jeff
ranscobia
Oct 14, 2015 07:32 PM
farmer460
Aug 22, 2014 02:08 PM
Vijay
15
May 28, 2014 04:49 PM
rlh
1978 - 1996 Big Bronco
Jan 19, 2004 11:44 PM
