HELLO to all my 3 week old 2010 f150 screw 6.5ft bed 4x4 5.4 3.73ls is leaning on the drivers side air pressure is 40 in all tires 18s drivers front is 37.25 pass is 37.25 drivers rear is 38 and pass is 39 measure from ground to topcenter of wheel well 1/2 tank of fuel i think it needs to be shimmed hope theres a tsb on it my 05 superduty was the same way had to put a 1 inch shim on drivers rear leaf spring this is kinda frustrating also they still havent figured out remote start to fix it so it doesnt kill when door is opened going back to dealer tomorrow
Not to be funny-is it leaning with you in or out of the truck? I know a couple of Louisiana boys and they are not little. If the truck is level empty but is leaning full, then I would look at the shocks on that side. Could be a bad one or even upside down. But that new, I would let the dealer figure it out. Chris
Well First off you can't take extact measurement when parked in the street or on a shop floor since they are not level enough. It would have to be on a frame machine that is set a dead level.
WELL MAYBE U CANT MEASURE IT BUT I SURE CAN AND MY SHOP IS LEVEL. I CAN SEE THE TRUCK IS LEANING
Forgive me for the question in this post. A few years ago I was restoring one of my MBZ G wagon when I found that the body was not quite level on the chassis. At first I thought that struts then springs but found that somewhere it the trucks life someone had the body off and forgot to put back some of the mounting washers. So here come the question if your chassis/frame is level with the floor of your shop but your body is not then take look at how Ford mounts the cab to the frame. If this is not the case then I would shoot a laser down the frame to check for any bents. Your truck could have had a problem after it left the factory. I remember once the Dodge dealership I used to buy from (now out of business), was taking delivery of some trucks when one rolled off the side of the ramp. You can guess what happened, it flipped on it's side doing a bit of damage. I asked what is going to happen with that one. I was told it would be sent to a shop and be repaired then sold at auction. Now will there be disclosure of what happened to this truck. I doubt if CarFax would report as it had not been titled. Just some more input for you, it may help or not. Chris
