6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
delete chip ??????????????????????????
Old Feb 8, 2010 | 04:51 PM
DEERSHOOTER's Avatar
DEERSHOOTER
my dealer says if i take the dpf out and filter and put a pipe in with delete chip that it will have allot more power and apperently if your a lil harder on the truck than a normal person that u will blow head gaskets and blow your trany and stuff what do you guys think that have this cuz know one who has this in there truck can resist puttin her to the floor ??? common so what do you think?????????
Old Feb 8, 2010 | 05:18 PM
ruschejj's Avatar
ruschejj
Go to Spartan Diesel Technologies.
Lots more power: yes
Engine failure possible: yes though unlikely if you monitor everything.
Don't expect your warranty to cover failed parts if you run a tuner.
Lay off the ??????????????????? button!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Mar 2, 2010 | 07:09 PM
killaguerilla's Avatar
killaguerilla
ive got an intake, edge programmer and and 4in pipes from the dpf back, cant find the right delete kit yet, but if i put the edge on level 4 it is fast as hell, put the foot to the floor on the regular, beat a challanger, charger, mustang, porche(the cheap one), and every truck that lines up, my edge has alerts so i set everything really low, so if it gets even 3 deg. hot it starts yellin at me
Old Mar 2, 2010 | 08:54 PM
BIG BLUE BEAST's Avatar
BIG BLUE BEAST
i've been wondering what would happen if you knocked the innards out of the DPF filter. like i use to do on cat's when they went bad... my last truck 01 sliverado had the cat's off for 8 years and i never had a problem and it pass emission's every year.
Old Mar 3, 2010 | 12:11 AM
DuallyMike's Avatar
DuallyMike
I hope one of the Ford techs responds to this. I thought I read in another post that this won't do anything cause you still have the sensor. Only make you buy a new DPF and they ain't cheap.
Old Mar 16, 2010 | 08:15 PM
Big Angry Hillbilly's Avatar
Big Angry Hillbilly
If you hammer the guts out of the DPF, it will likely go into regeneration, and stay there.
You will have at MOST 667 miles before it goes into regeneration if you have the latest calibration.
You can smash the innards out, but you'll still need a tuner.
Old Mar 18, 2010 | 12:21 PM
killaguerilla
I was thinking the exact opposite, the reason the truck goes into regen is the sesor tells it that the dpf is dirty, limited flow through filter, with no filter i might think that the free flow would trick it into thinking that the filter is clean, or mabye it would sniff all the smoke in the pipes an regen, if anyone does it let us know huh??
Old Mar 18, 2010 | 01:19 PM
66stang351's Avatar
66stang351
The problem is that there is a failsafe that forces regen after a certain amount of miles...if you don't have a working filter in place at that time it stays in regen mode continuously.
Old Mar 18, 2010 | 05:21 PM
BIG BLUE BEAST
i let you guy's know what happens. got a filter off a wrecked 08 today and just got through removing the (guts ) of the filter. i will install my empty one on saturday and see what happens. i'll keep you guys posted.
Old Mar 18, 2010 | 08:58 PM
jimd1050's Avatar
jimd1050
BuhBye F450, I'm relaxin'
Please do let us know - I was thinking of trying it just for the visual inspections that are undoubtedly coming. Cops with a mirror on a stick, etc. - if the DPF and CAT seem to be intact visually, they are less likely to look any further!
Old Mar 21, 2010 | 10:35 AM
BIG BLUE BEAST
well now that was a wast of time on a good saturday. put the empty filter on the truck and it went into regen after ten miles and stayed there also the check engine light came on. truck ran like a bag of CRAP. disconnected the Batteries and tried again no luck. put the filter back on, hooked up the batteries and all was good.
Old Mar 22, 2010 | 03:32 PM
edjunior's Avatar
edjunior
Well there you go. You can fool some of the people some of the time, but you can't fool the DPF! Interesting thread!
Old Mar 22, 2010 | 06:39 PM
BIG BLUE BEAST
yeah i though i could get away with something for free. just my labor. ha was i wrong. boy am i a loser.
Old Mar 23, 2010 | 09:26 AM
kylebryan's Avatar
kylebryan
Ive been running a spartan for a couple months now without my DPF and the truck runs great. better mileage (17hwy) and no regens. I would check with spartan if youre thinkin about removing the DPF. They have the best tuner on the market. Also the spartan is undetectable once removed so all warranty work should be covered.
Old Mar 23, 2010 | 04:38 PM
StanleyZ's Avatar
StanleyZ
you know I hear that about these programmers being undetectable but I just don't believe it. It's a computer and has to have a hard drive of some sort which will retain historical data at least until the program space is needed. Besides, I just feel sure that Ford has programmers smart enough to think about performance chips when the computer was designed. Now, the tech at the local dealership may not have the tools to retrieve the data but I'm just betting someone does. I could be wrong, but I'm just saying!!!!
