low operating temp
Old Feb 8, 2010 | 02:56 PM
6.9lidiguy's Avatar
6.9lidiguy
low operating temp
could the heater lines be hooked up backwords? my temp guage never comes up much at all. my other temp guage i in stalled also always reads cold.
Old Feb 8, 2010 | 03:06 PM
RRranch's Avatar
RRranch
The heater lines don't matter. You probably need a new thermostat and replace the rad cap while you are at it.
Old Feb 8, 2010 | 03:14 PM
6.9lidiguy's Avatar
6.9lidiguy
it has new thermostat and cap
Old Feb 8, 2010 | 04:53 PM
IDIDieselJohn's Avatar
IDIDieselJohn
How cold is cold?
Old Feb 8, 2010 | 06:02 PM
johnboggs21's Avatar
johnboggs21
Im lucky if mine gets up to N on the gauge this time of year. But as long as ive got heat in the cab it never really worries me that much.
Old Feb 8, 2010 | 06:32 PM
gonecrazyi's Avatar
gonecrazyi
My last motor wouldnt ever put out any heat, but here in Florida it doesnt get very cold so I didnt worry about. It never overheated so I figured it was fine. I did pull the tstat when the motor died but I have yet to test it tos see if that was the problem.
Old Feb 8, 2010 | 07:14 PM
fuzzy1626's Avatar
fuzzy1626
Was it a Mortorcraft thermostat? Is the fan clutch locked up?
Old Feb 8, 2010 | 07:34 PM
johnboggs21
Theirs some guys on here that take the fans off for the winter. Ive been meanin to do it, but it hasnt been as cold as i thought and a lack of funds keeps me from drivin the ole rig as much as Id like to.
Old Feb 8, 2010 | 10:27 PM
starmilt's Avatar
starmilt
You need to flush out your heater core more than likely, it should put out heat even if the motor is only 100 degrees. I don't know anybody that removes their fan for the winter, David 85 did run his for a while to test the mileage. If you have a mechanical guage install a mexican thermastat and see if it warms up. Is your fan clutch locked up and how far at a time are you driving it.
Old Feb 8, 2010 | 10:59 PM
87crewdually's Avatar
87crewdually
Originally Posted by starmilt
install a mexican thermastat .
O.K. What the heck is that? Slang or something or you really saying a thermostat built in Mexico. Enlighten me!
Old Feb 8, 2010 | 11:06 PM
starmilt's Avatar
starmilt
LMAO a piece of card board just to see if it heats up.lol
Old Feb 8, 2010 | 11:11 PM
87crewdually
I knew you had some kind of answer. I was thinking you meant run it without one or something. lol. too much
Old Feb 8, 2010 | 11:25 PM
starmilt's Avatar
starmilt
A few years ago a friend of mine was up north and the temps got way below 0, when he got back to town he had his matress tied to the grill on his kw. I about rolled on the ground and still give him a hard time about it.
Old Feb 8, 2010 | 11:53 PM
6.9lidiguy's Avatar
6.9lidiguy
im talking 130 deg. in the summer even when its 95 deg. out side on the factory guage it barely registers. im in southern california and the coldest monrnings ive had were maybe 25 deg. but its 75 within a couple of hours. and the truck still never gets in the normal range. im pretty sure i installed a motorcraft t stat
Old Feb 9, 2010 | 03:43 PM
drewdole's Avatar
drewdole
mine stays at 185 or 190 i did change my gauge to an auto meter one , with numbers on it . i g just put in a new modine rad. too i m in the south
