Answer to everyone's question!
Old Feb 8, 2010 | 10:36 PM
66gpw's Avatar
66gpw
You know I seen some right hand drive cars here. The gas and brake pedals are like ours. gas on the right , brake and clutches on the left.
Now I would not say that is for sure, but the right hand ones that have been imported here in Canada have them that way, unless they change them after they send them here.
Old Feb 8, 2010 | 10:49 PM
rtcalabrojr's Avatar
rtcalabrojr
Darksider
SAD, SAD .............................
Old Feb 8, 2010 | 11:40 PM
fixnair's Avatar
fixnair
Where can I get three or four?
Old Feb 9, 2010 | 07:43 AM
57Blueboat's Avatar
57Blueboat
The pedal set up is the same regardless of left or right hand drive around the world.
Old Feb 9, 2010 | 08:00 PM
deyomatic's Avatar
deyomatic
The shift pattern is the same, too and the "indicator" is on the left. It's much tougher getting used to the side of the road than shifting with the left hand. When you pull up to a stop sign, and want to take a right turn, which direction do you concentrate on? The first two days are spent second guessing your instincts but you get used to it.
The toughest part about the shifter is the downshifting part. When you are cruising along at 50mph or so in your vehicle and some clown in a Civic with a wing speeds past you, you PULL the stick from third back and toward your body to hit second...same with fifth to fourth. With right hand drive, you have to pull the stick out of third and push down and away to hit second...more than twice I hit fourth unexpectedly.
Ireland (Munster) is the greatest place I've ever driven.
Old Feb 9, 2010 | 08:17 PM
carnut122's Avatar
carnut122
That rocks! I sure miss my Mustang!
Old Feb 9, 2010 | 09:56 PM
4tl8ford's Avatar
4tl8ford
Originally Posted by abe
Another question about the brits and Aussies: on a right hand frive car, is the gas pedal on the left foot or the right?????
They don't have gas pedals
Old Feb 10, 2010 | 09:19 AM
GreatNorthWoods's Avatar
GreatNorthWoods
Petrol pedals?
Old Feb 15, 2010 | 07:33 PM
53pickemuptruck's Avatar
53pickemuptruck
Whoompa!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!
wr400f250
Engine Swaps
Dec 5, 2011 09:02 PM
john fin
Oct 24, 2011 02:48 PM
blackbetsy
1978 - 1996 Big Bronco
Sep 30, 2011 01:55 PM
640 CI Aluminum FORD
EcoBoost (all engine sizes)
May 9, 2011 11:13 AM
PowerstrokeJunkie
21
Apr 21, 2008 06:27 PM
