Will these work?
Old Jan 18, 2003 | 02:08 PM
bucky48's Avatar
bucky48
Will these work?
Im thinking on bidding on these, im going to put a 460 into my 79 shortbox 4x4. the guy says they will work for a 2wd but im not sure if theres a difference for a 4wd. any help will be appreciated . thanks.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2400365312
Jim
Old Jan 18, 2003 | 03:03 PM
Mil1ion's Avatar
Mil1ion
Will these work?
That's only 2 pieces of the needed 6.
I would look for the whole set to purchase instead.
Old Jan 18, 2003 | 05:01 PM
ecarter50's Avatar
ecarter50
Will these work?
As mil1ion said they are missing the part that bolts on the engine. They will fit 2wd only. You will have to buy aftermarket mounts for 460 in a 4wd.
http://www.landlproducts.com/
http://performanceunlimited.com/cust...ginemount.html
Old Jan 18, 2003 | 08:38 PM
Mil1ion's Avatar
Mil1ion
Will these work?
Actually, I'm pretty sure the towers,mounts,insulators are the same on the 429/460 <> 2x4 & 4x4.
The difference is the rear sump pan,oil-pickup, and power steering brackets.
I just wouldn't buy 1/3 of the system I need than wonder when I will find the rest.
It should be eaier to find the whole set.
Old Jan 19, 2003 | 12:56 AM
ecarter50's Avatar
ecarter50
Will these work?
A 460 was not factory installed in a 4x4 until 83. You will need to use 351m/400 4x4 frame brackets similar to the ones in the attached picture with aftermarket mounts.
