4x4 Auto
Old Feb 7, 2010 | 09:30 PM
devink's Avatar
devink
4x4 Auto
Correct me if I am wrong, the Auto feature in the 4x4 is operated on vacuum. Locking the hubs in is 4x4 with the switch in 4x4. I have an 04 and I was wondering if and what there is to fix the vacuum 4x4 when in the unlock or free postion with the front hubs. I also noticed when the hubs are locked in and I put it in 4x4 my heater will change to defrost no matter what I have it set on. Any Ideas?--Thanks
Old Feb 7, 2010 | 09:35 PM
cheezit's Avatar
cheezit
you have a vacuume leak would be my guess. anytime there is a loss of vacuum to the a/c controll head it will always default to defrost.
with autolocking hubs yes they are vacuume operated. they can be engauged by hand if you so choose though.
Old Feb 7, 2010 | 09:38 PM
jeepster1272's Avatar
jeepster1272
had the same problem in my 2001 7.3, turned out to be a bad vaccum pump.
Old Feb 8, 2010 | 05:36 PM
devink's Avatar
devink
Do remember what it cost you to get that replaced?
Old Feb 8, 2010 | 06:46 PM
jeepster1272
It was not that expensive if my mind serves correct. got the vaccum pump at dealer, easy to replace, but check all your lines going to it as well.
