question about gen. reg.
Old May 31, 1999 | 10:51 AM
fordfan's Avatar
fordfan
Can you adjust the curent going to the battery? My
book says you can and has a picture but it does not match up.
Old Jun 10, 1999 | 10:57 PM
nick's Avatar
nick
It is possible if you have the right kind of regulator. Mine was non ajdustable and it wnet south and I'm working on replacing it. Im not sure how to tell if it is adjustable or not.
Old Jun 11, 1999 | 03:13 PM
Mulletwagon's Avatar
Mulletwagon
The old generator regulators used spring-loaded relays to control voltage and current. By bending the spring mounts and changing the spring tension some adjustment was possible. If your generator or regulator dies the best thing to do is convert to an alternator system. The conversion is remarkably easy (for 12 volt system) and would be trouble free for at least 100,000 miles; not to mention plenty of current at low rpm.
Old Jun 11, 1999 | 06:08 PM
Passman
Guest
Posts: n/a
spdmpo
Feb 19, 2010 07:28 PM
Big_Dom
Feb 10, 2010 10:00 PM
MeanMom
All Things Towing
18
May 7, 2008 06:19 PM
FTE Ken
21
Apr 11, 2003 10:16 PM
Greywolf
Dec 7, 2002 11:38 AM
