6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Tuner Questions
Old Feb 6, 2010 | 06:25 PM
Trancebear's Avatar
Trancebear
Tuner Questions
I am shopping for a new tuner for my 09 6.4L PS and I was wondering if you guys have heard of/used the 6.4L Twin Turbo Powerstroke Diesel Diablosport Predator Tuner from DiabloSport? I have a budget of $500 so I cannot afford the real good ones like Spartan. This tuner claims:
U7164 Stock Vehicle Tunes:
# Tow Tune
# 50hp Economy Performance Tune
# 80hp High Performance Tune
# 160hp Extreme Tune
I have searched for a thread that compares the current tuners and I can't find it. If anybody can point me to it I would be very happy. Thanks.
Old Feb 6, 2010 | 09:45 PM
Brandon D's Avatar
Brandon D
Lead Foot User
The only advice I will give is to give it some serious thought. Do you really want to cheap out on a product that can not only destroy your engine or driveline but then also void your warranty if such problems do occur? If you can't afford a higher quality "proven" tuner then you'd be a lot better off to leave the truck stock. This is just my opinion but I would never shell out 50K on a new vehicle and then try and save $1500 on a tuner and have problems. Enjoy it as is and save up the money to do it right. Good Luck
Old Feb 6, 2010 | 09:52 PM
Trancebear's Avatar
Trancebear
I cannot believe that it is a requirement to spend $1500 for a tuner. I would never buy a cheaply made tuner but who says $1500 is the starting point? What I am looking for is someone who has used a lower priced tuner and have had good luck. That way there would be little risk if it worked for someone else.
Old Feb 6, 2010 | 09:57 PM
Brandon D's Avatar
Brandon D
Lead Foot User
I never said it was a requirement to spend $1500 on a tuner. I was simply speaking of the Spartan tuner that has easily had the best reviews on this forum. There are plenty of cheap tuners out there that "might" work just fine for you. I was simply offering my opinion. Do what you want in the end because it's your truck and you have to live with any possible repair bills, not me.
Old Feb 7, 2010 | 06:34 AM
senix's Avatar
senix
SCT, Spartan and I have the banks. Those seem to be the best for this truck. Listen to Brandon and do your research.
Old Feb 11, 2010 | 03:02 PM
bscooter99's Avatar
bscooter99
well while i dont know about diablo on the 6.4s i had a friend that went with diablo on a 6.0 and blew the head gaskets...i have heard that diablo is not the way to go but personally have no experience with that product myself...i had an sct sf3 custom tuned on my old 6.0 and had no problems...now that i have a 6.4 im trying to decide between sct and spartan...anyways hope that helps
Old Feb 11, 2010 | 03:39 PM
sdetweil's Avatar
sdetweil
but 6.0s had a head bolt design that was close to tolerance, thus the head gasket impact. seems the 6.4s have much more tolerance built in.
Sam
Old Feb 11, 2010 | 03:54 PM
jeff7825's Avatar
jeff7825
I am new to the 6.4, (only had mine a few weeks) so this is just from the research that I have done. A few vendors use the SCT software, so that is kind of nice there that you wouldn't have to buy a new tuner if you wanted to switch tunes. The SCT also comes pre-loaded with tunes as well, and it is cheaper than the Spartan. The Spartan comes loaded with 12 tunes, which is a great bonus I think. Plus I hear that the DashDaq is a better gauge monitor than the Livewire, but Spartan is a little more pricey. Then you have to add in your delete pipes or exhaust. I think that I would save up a bit more money a buy a better tuner. The Livewire starts around $650 and you could run it for a while and then add custom tunes to it later. Personally I will be deciding between tunes from Spartan or Innovative Diesel.
Old Feb 11, 2010 | 04:07 PM
sdetweil's Avatar
sdetweil
I think u need to remove the DPF to get any MPG increase (turn off regen)
Sam
Old Feb 11, 2010 | 04:40 PM
thunder64ybd's Avatar
thunder64ybd
Trailering
# Tow Tune
Trancebear ; I have a 2008 f250 I have the Bully Dog Power Pup have had it for 2 years or so no problem truck is stock the unit new is $599.00 www.bullydog.com site from time to time I pull A fifth wheel put it in to tow mode the bully dog unit, and it dose fine any other time it is in performance mode works fine for me. Im not sure for the 09 model they make the Triple Dog $649.00 new check there web site out. hope this help
Old Feb 11, 2010 | 04:46 PM
callmebobvilla's Avatar
callmebobvilla
thunder64ydb have you seen an improvement in mpg's?
Old Feb 11, 2010 | 04:52 PM
thunder64ybd
Trailering
3 more mpg if I stay around 2000 or so rpms not so much when pullying camper but I do have more hp in tow mode
Old Feb 11, 2010 | 05:17 PM
callmebobvilla
That's pretty impressive. The bully dog maintains the DPF right? Have you had any dealer/warranty issues?
Old Feb 11, 2010 | 06:07 PM
thunder64ybd
Trailering
I put it back to stock before I take it in have had no peoblem
Old Feb 11, 2010 | 06:09 PM
thunder64ybd
Trailering
yes it dose maintains the DPF
