Tuner Questions
SCT installed with DPF delete $1900 at a dealer
I have an 08 350 6.4L. Dealer nearby has a pro shop. they install SCT livewire DPF delete etc... total package is $1900. Does this sound reasonable? they also continue to cover the truck.... however i heard you sign a waver so not sure how much they back it but they have done many trucks and none have come back... ive been thinking spartan but if these guys do it and cover it then maybe i go for it. my main goal is to increase MPG
Trancebear ; I have a 2008 f250 I have the Bully Dog Power Pup have had it for 2 years or so no problem truck is stock the unit new is $599.00 www.bullydog.com site from time to time I pull A fifth wheel put it in to tow mode the bully dog unit, and it dose fine any other time it is in performance mode works fine for me. Im not sure for the 09 model they make the Triple Dog $649.00 new check there web site out. hope this help
Do you monitor every parameter your OBDII has to offer? To you monitor anything with the bulldog? I think when you begin to add power, and you are using the truck to pull heavy loads, it is extremely important to pay close attention the your trucks vitals. That is what I love about the Dashdaq. I monitor EVERYTHING haha
Thanks for the info. Did you install your own? it was suggested by someone that i get CAT/DPf kit as its easier to re-install if you goto dealer. of course this dealer says he'll cover things BUt if i do myself and re-install then i dont have to worry about warranty. Do you have SCT or Spartan? Does SCt/Spartan leave a trail of any sort? Also how much did your MPg increase?
Like mick said returned my truck to stock many times and sent back to dealer and no problems. And as for the $5-$600 tuners you are wasting your money. Tried them now they are sitting on the shelf collecting dust. Sold Edge for $300 just to get rid of it. Save yor money and call Spartan. Your not only getting a tuner but something that is not tracable once set back to stock. That is worth the price when it saves your warranty.
I also only run Spartan.
Spartan or SCT
Thanks for the input. I know on the SCT you can flash and remove you dont have to mount the unit. Can you flash with the Spartan and not mount it? i want to flash and leave until i tow or goto dealer and really dont want anyting mounted on dash etc... Can you run spartan with DPF on? i know MPG will not be as good with DPf on but also less work replacing everything. Thanks for your input as im getting educated before i drop $$. My goal increase MPG 3+.
Yes you can. But if I were you I would use it. It already has the gauges setup to alert you if anything gets out of limits. You get 4 dpf on tunes with the basic unit and 8 others. You can mount it with the suction cup mount that's easily removed..... And yes, you should see at least a 3 mpg increase.
#28
#29
#30
