Newbie here that needs some help.... I'm trying to help my father out. While trying to change the Cam Position Sensor in his 2002 Ford F250 Diesel, it broke off almost flush and I was wandering if anyone could tell me how the hell to get it out now.......Any help is greatly appreciated.
Piece should be NOT able to fall inside. The clearance between the cam sensor and cam gear is very close. I can't quote the exact distance, but unless it was just a sliver it would not fall in. Drill and screw seems to be the best and quickest solution to its removal. Good luck!
