Will a flashed PCM throw a P0603?
Old Feb 6, 2010 | 03:59 PM
FreeDevin's Avatar
FreeDevin
I ask because I am still getting a P0603 DTC. However, upon removal and inspection of the PCM, there is no chip installed.
I suspect the PCM was flashed by the original owner because the P0603 DTC is being thrown, there is no physical modification and....drum roll....there is a SuperChips sticker inside the glovebox!!
Old Feb 6, 2010 | 04:34 PM
don77's Avatar
don77
fuel pump question
if the light comes on and truck shakes bad and no power can it but the fuel pump
Old Feb 6, 2010 | 04:40 PM
clem1226's Avatar
clem1226
I think I would rather find out I was adopted than my truck had been flashed with a superchip tune by the PO.
man I hope this is not the case for you
good luck .
Nothing to add just a bump at the least
Old Feb 6, 2010 | 04:56 PM
DP-Tuner's Avatar
DP-Tuner
PREMIUM SPONSOR
That is a common code to get when you flash the PCM or add a chip.
Why not reflash the PCM to a factory flash? This will make it go away.
Diane
__________________
Jody & Diane Tipton- DP-Tuner®
FTE Legacy Sponsors since 2006
Custom tuning for 7.3l, 6.0l, 6.4l,6.7l, Ecoboost,
Get Tuned! 828-221-0076 ext. 802
Become our Facebook Fan
Old Feb 6, 2010 | 06:53 PM
rbaker6336's Avatar
rbaker6336
can a PCM be reflashed to a different code like to a PMT1
Old Feb 6, 2010 | 07:10 PM
FreeDevin's Avatar
FreeDevin
Ok, this makes sense then. Thanks for your input, Diane.
I do not have any engine problems and the truck runs like a whistle. I'll leave her be for now.
I'm not interested in any aftermarket parts/programming. I just want her to see 300,000 miles and take good care of her so she will take good care of me.
Old Feb 6, 2010 | 07:29 PM
DP-Tuner's Avatar
DP-Tuner
PREMIUM SPONSOR
As long as its a PCM from a DPC-422 family.
__________________
Old Feb 6, 2010 | 07:43 PM
rbaker6336's Avatar
rbaker6336
Then you can reflash my MNM1 to a PMT1 or PMT2
Old Feb 6, 2010 | 07:50 PM
DP-Tuner's Avatar
DP-Tuner
PREMIUM SPONSOR
Yes it can be.
__________________
vloney
34
Dec 17, 2015 06:14 PM
ZombiePopper
Feb 26, 2015 06:37 PM
Restlesswildman
Sep 22, 2014 07:37 PM
WatsonR
Jul 18, 2014 07:53 PM
DaveCinIN
Mar 21, 2014 08:49 PM
