Timing change
Old Jun 19, 1999 | 04:57 PM
Fordman's Avatar
Fordman
Timing change
I recently had the timing turned up in my pickup because it was getting pretty doggy and was way off according to the guy that turned it up. I couldnt get much accelleration or get up and go out of it. So I had it turned up (since I dont know how to do it myself) and the pickup has more power but still not the snap that I am looking for. When you really put your foot in it the engine starts to rap up but then it kind of falters and makes a low rumbleing sound but when I back out of it a little it quits and accelleration increases. I thought the harder you push on the go pedal the faster you acclerate. Any ideas?? It has a stock 351M in it.
Fordman
Old Jun 20, 1999 | 10:12 AM
Bruce's Avatar
Bruce
Timing change
First things first, do you have a stick or automatic? this will help us diagnose your problems. Also, do you have a 2-bbl or 4-bbl carb?
When you say it starts to rap up do you mean that it begins to accelerate great?
The rumbling sound, does it come from the engine compartment or from below or behind you, as in the mufflers or tail pipes?
Do you hear any knocking or pinging from your engine, kinda like little metal on metal taps comming from the engine?
Answers to these will help.
Bruce
Old Jun 20, 1999 | 10:15 AM
Bruce's Avatar
Bruce
Timing change
One other question - when you mash the pedal do you see any smoke behind you? Do you see gray or black smoke or none at all?
Thanks.
Bruce
Old Jun 20, 1999 | 10:24 AM
Fordman's Avatar
Fordman
Timing change
I have a manual transmission (an NP 435 I think) A stock Motorcraft 2bbl carb. The rumble comes from the engine compartment because my mufflers make a different tone sound than this. And finally the engine doesnt ping when you really get into it. I made sure of that before I took it home from the shop. I hope this give you enough info to make a diagnosis
Thanks
Fordman
Old Jun 20, 1999 | 10:26 AM
Fordman's Avatar
Fordman
Timing change
When I romp on the gas no smoke appears from the pipes. The engine is still in pretty good shape so it doesnt use oil.
Old Jun 20, 1999 | 07:19 PM
rick's Avatar
rick
Timing change
First off it DOES NOT take a rocket scientist to adjust timing, you can certainly do this yourself, heres what has been recomended to me and countless others by "Pony Carburetors" : With engine at normal operating temp. and vacuum advance hooked up, turn your distributer clockwise until you get the highest rpm out of it, it will tell you you've gone too far by starting to buck and slow down, then lock distributer down & test drive, if engine pings on acceleration back off just a hair at a time until engine just pings or just barely does not, your engine will definatly run better and give more gas mileage, They also recomend switching to PREMIMUM GASOLINE.
One more thing... How long since your last "tune-up"? how about the all important FUEL FILTER? Rick
Old Jun 21, 1999 | 09:25 AM
slik's Avatar
slik
Timing change
Farmer_Jack_13
Oct 24, 2016 12:26 PM
Jaynen1
Modular V8 (4.6L, 5.4L)
Jul 14, 2015 10:54 AM
427 fordman
46
Mar 29, 2015 10:07 PM
drusher
54
Jan 19, 2012 11:44 PM
dbmartin
Jul 14, 2009 11:42 PM
