1978 - 1996 Big Bronco
backfiring
Old Feb 6, 2010 | 04:03 AM
hatchet's Avatar
hatchet
backfiring
my 96 bronco backfires every now and then why does it does this?
Old Feb 6, 2010 | 11:28 AM
Encho's Avatar
Encho
The Southernmost Mod
It can be caused by a lot of things, Including worn or bad spark plugs or cables, bad timing, damaged sensors... too many things to list. For a basic definition on "backfire", try wikipedia, it will help you understand.
Old Feb 6, 2010 | 12:31 PM
Kemicalburns's Avatar
Kemicalburns
PULL CODES and see what the computer is seeing
Old Feb 6, 2010 | 01:26 PM
Beechkid's Avatar
Beechkid
Typically...
Ignition or cam timing out of phase
Old Feb 6, 2010 | 08:22 PM
greystreak92's Avatar
greystreak92
Pull fault codes FIRST! Otherwise you are on a wild goose chase guessing at what part of the ignition system is causing the problem. KOEO and KOER tests will definitely yield some code(s) if the engine has misfired.
ClassicIndy650
Jan 26, 2014 02:14 PM
ColtonMullis
Jan 20, 2014 03:53 PM
Ratsmoker
Oct 25, 2002 01:18 PM
Syko
Jun 13, 2002 08:52 AM
jakegypsum
Oct 30, 2001 04:09 PM
