backfiring
It can be caused by a lot of things, Including worn or bad spark plugs or cables, bad timing, damaged sensors... too many things to list. For a basic definition on "backfire", try wikipedia, it will help you understand.
Pull fault codes FIRST! Otherwise you are on a wild goose chase guessing at what part of the ignition system is causing the problem. KOEO and KOER tests will definitely yield some code(s) if the engine has misfired.
ColtonMullis
Jan 20, 2014 03:53 PM
Ratsmoker
Oct 25, 2002 01:18 PM
jakegypsum
Oct 30, 2001 04:09 PM
