cild air intake
Old Feb 5, 2010 | 05:54 PM
JERRY WESCOTT's Avatar
JERRY WESCOTT
cild air intake
just purchased a 2006 f150 with 5.4 L engine I need help finding which cold air intakes worth while buying there so many out there it's hard to pick one
Old Feb 5, 2010 | 07:37 PM
Beechkid's Avatar
Beechkid
If you do an online search for “air filter test” there is a lot of very good information. IMHO, the CAI units are NOT WORTH THE $$! Unless you are talking about a system that was specifically designed for a specific application there are very little hp/tq gains actually achieved in a street use vehicle and there are very few docs that these mfg’s can produce that actually show an increase in hp/tq in the power-band range of a relatively stock street vehicle.
I would avoid oil impregnated filters. While they have their purpose in off-road applications, Ford/GM/Dodge all have “watch-out” bulletins where the oil has contaminated intake sensors. - they even have a training video for the tech's on this (flatratetech.com) .
If you look at the flow data, WIX HP filters flow 98+% of K&N and have a much smoother flow post filter plus excellent filtering, for a fraction of the price! The OE’s have an excellent air intake system. What many view as an issue (is the plastic intake tube with it’s noise canceling design) actually increases air pressure. It is the same hydraulic concept used by fire fighters creating water supply where psi is low. By having the air cross the path at a 90 degree angle, the pressure is increased proportionally. Fire fighters use what is called a “4-way valve” or “Blake Valve” at the hydrant where the water is cycled through the fire engine (pump) and sent back into the valve crossing the water flow at a 90 degree angle. In this case it also acts as a sound canceling device! At low speeds, this can reduce the flow a tad (which is what most “feel”), but in terms of peak hp/tq, a good high flow filter is all that is needed. You can use a WIX OEM HP replacement filter in the OEM plastic manifold box and either remove the plastic tube and replace it with a piece of pipe/hose, etc or remove the tube completely and replace the tube by building an air ram type intake into the air box manifold (where the pipe use to attach)- make sure ti terminates above the fan shroud to avoid water intake or fan induced pulsations.
Old Feb 6, 2010 | 08:54 PM
LxMan1's Avatar
LxMan1
None are worth the $250+ price tag for sure.
Nseal1996
Aug 2, 2014 08:33 PM
trucker01
16
May 10, 2014 09:23 PM
vczar1
Mar 17, 2013 06:23 PM
mudlite
2004 - 2008 F150
24
Sep 20, 2008 07:19 PM
Jackson
16
Feb 9, 2005 11:30 AM
