15" or 17" steering wheel?
Old Jun 24, 1999 | 05:01 PM
mark rogers
Guest
Posts: n/a
I am converting my 68 F-100 2wd from manuel to power steering. I will be changing the pump/gear.
I would like to get rid of the old 17". If I put in a P/S unit from a mid-70's F-100, will I have to stick with a 17" or can I downsize to a 16" or maybe even a 15" and not have any problems?
Love to hear your thoughts!
Old Jun 24, 1999 | 06:47 PM
Dan64F100's Avatar
Dan64F100
The steering wheel from a '70-77 Ford truck should fit, although I think it is almost as large in diameter (maybe 16"?) as the '61-'69 3-spoke. The '78 and later wheel (with sharper angles in horn pad area) is smaller, but has a different size steering column diameter, so the wheel and column don't line up correctly.
Perhaps one of the passenger car wheels would work better. Good luck!
Old Jun 24, 1999 | 10:57 PM
jowilker's Avatar
jowilker
Mark, I don't know what your plan is for the conversion, but you will need to change the column as well. The gear is a couple of inches longer where the hoses connect, so the shaft length will have to be compensated. I have made a conversion for a 66 F100 from a 76 F100.
Is your truck auto or straight drive, what size is the engine. If you will email me at jowilker with your responses I'll try to help you with your conversion, and what you will need.
John
Old Jun 24, 1999 | 11:20 PM
CrazyWoman's Avatar
CrazyWoman
Mark,
a larger diameter steering wheel has more "leverage" and is easier to turn than a smaller one, thus the 17 incher on your manual steering.
With power steering, a 15 would be fine, except if your power steering goes out! Then it would take a herd of elephants to steer that mother around anything under 30mph (believe me, I know!)
CW<<getting more muscular arms everyday!--(arg)
Old Jun 25, 1999 | 06:10 PM
Trevor Rush's Avatar
Trevor Rush
Hi Mark, I have '67 F100 with Power Steering (it came that way)and I switched to a 15" Grant Wheel in late '90, when they first came out, and wouldn't switch back.
Old Jun 29, 1999 | 03:03 PM
Marty's Avatar
Marty
I have a smaller after-market wheel on my 73, it's 12-13 inches. I have had manual steering until yesterday (just did the conversion). It was tougher at lower speeds, but bearable. I love the smaller wheel (especially with power steering) and would never go back to one of those big monster wheels like it originally had.
Old Jun 30, 1999 | 12:11 AM
Vinc
Guest
Posts: n/a
Mdc9966
20
Jun 30, 2017 12:42 PM
Mdc9966
Dec 5, 2016 02:41 PM
gabby4244
2009 - 2014 F150
Aug 22, 2016 09:11 PM
FossenRacing
May 25, 2011 02:13 PM
BarnieTrk
Aug 7, 2007 07:06 PM
