Sponsored by: Auxito
Huge Clunk
Old Feb 5, 2010 | 11:00 AM
Flareside50's Avatar
Flareside50
Huge Clunk
OK so this has been happening for a while, pretty much since I got the truck but it is really starting to annoy me. I have a 99 5.4 flareside. Everytime it is wet meaning snow or rain the truck clunks really loud going around corners. It is just one loud clunk and it only does it when it's wet. I have no idea why but it doesn't sound good. Like I said its been doing this for a while anybody no where I should look. Thanks
Old Feb 5, 2010 | 11:54 AM
Joe Finn's Avatar
Joe Finn
Check the sway bar end links.
Old Feb 5, 2010 | 07:48 PM
Flareside50
I changed the end links not that long ago and I was under the truck the other day and they appear to be fine. It seems like it is coming from the rear of the truck
Old Feb 5, 2010 | 10:09 PM
jonhas's Avatar
jonhas
i had a similar noise a year ago and it turned out to be the tool box wasn't fastened tight enough . i guess it would slide easier on the box liner when it was wet. tightened it up and no more noise.
Old Feb 7, 2010 | 01:07 PM
ddelong's Avatar
ddelong
I have a 99 F150 and I heard the same thing a few weeks ago when I used the truck to haul a snowmobile trailer. I went around a corner when it was snowing out and CLUNCK. It sounded like a big piece of ice got jammed in the wheel well but it wasn't. I haven't had it happen in quite a while but then, again, I don't use the truck that much.
Sorry I can't help you but I will be following this item since it does apply to my 99 Ford.
Old Feb 7, 2010 | 02:52 PM
Joe Finn's Avatar
Joe Finn
You might want to take a good look at the leaf springs. It's not unheard of for the to break and try to jump out of the pack. I had one let go about 2 years ago. Look for cracks in the mounting pad area.
jrjudd
Feb 15, 2010 10:09 AM
superduty4x4
Mar 26, 2008 09:01 PM
mrl390
Sep 22, 2006 10:04 PM
Brians97F250Crew
Mar 19, 2006 08:42 AM
johnanderson
Dec 4, 2003 12:06 AM
