Offroad & 4x4
What Items needed?
Old Feb 5, 2010 | 09:07 AM
darthice's Avatar
darthice
What Items needed?
What items do i need to do a solid axle swap on my 92 f150. Has anyone done one on a 92-96 f150? If so can someone post or pm me the list of items needed to do this conversion.
Thank you very much. I figure that if i am going to make my truck 4wd might as well make it worth my while. Also what type of lift kit works with a Solid axle since the ones for my year truck wouldnt work for the f150 version
Old Feb 5, 2010 | 09:13 AM
alpha/omega's Avatar
alpha/omega
Karl (kjett) has done a SAS on a 96 F150. Real bad truck but its slow.
Youll need a 78/79 F150 Dana 44 front axle assembly to include: drag link and tie rod, track bar, radius arms and brackets and the lower coil spring cups. Im pretty sure Karl kept his factory 96 upper spring buckets but Id wait on him to fill you in there.
Lift springs would come from a 73-79 F150 as well. I recommend Deavers.
Old Feb 5, 2010 | 09:20 AM
darthice's Avatar
darthice
thanks yeah i was just going to do ttb on it but honestly if i want it how i want it to be in the end i am going to need a sas in order to handle the tires and some of the places i go i am going to need a solid front axle
Old Feb 5, 2010 | 09:27 AM
alpha/omega
what size tires and what do you intend to do with it?
Old Feb 5, 2010 | 09:30 AM
darthice's Avatar
darthice
at least 35s maybe some 37" hummvee tires
Old Feb 5, 2010 | 09:39 AM
alpha/omega
should be pretty good with a D44 front and 4.10-4.56 gears depending on engine and transmission.
Old Feb 5, 2010 | 09:45 AM
hokie93's Avatar
hokie93
If you're gonna do an SAS and have the cash you shoud do a D60. If you don't have the cash or can't find a D60 a D44 will be fine with 35's.
Old Feb 5, 2010 | 09:56 AM
alpha/omega
a $1000 d60 would be a waste IMO for 35s unless he plans to beat the **** out of it on a weekly basis.
Old Feb 5, 2010 | 09:59 AM
darthice's Avatar
darthice
na just a toy to get through the deer woods and play every once in a while
Old Feb 5, 2010 | 10:18 AM
alpha/omega
D44 and never look back.
Old Feb 5, 2010 | 10:22 AM
darthice's Avatar
darthice
i thought so and i was reading on 9 ford 5 s sas conversion thread that you can use your ttb rad arm brackets for the sas as long as you use the ttb bushings This will make things a whole lot easier if its true.
Old Feb 5, 2010 | 12:19 PM
Bender99's Avatar
Bender99
You probly could but It's gonna need to be moved cause the 70's rad arms are longer and depending on how much lift you use you might want them to drop lower.
Also, the 78/79 drag link is too long for the newer trucks, use a 90's 4x4 f350 drag link in combo with the 78 tie rod.
Old Feb 5, 2010 | 02:29 PM
darthice's Avatar
darthice
thanks for the info i will do that when i get it all set up
Murder_Bronco_2
Oct 27, 2016 05:05 PM
olrebelford28
Dec 23, 2015 01:21 AM
pitpawten
Nov 23, 2015 03:04 PM
dixie460
19
Nov 19, 2015 10:10 PM
jimjoebob99
27
Dec 28, 2009 07:25 AM
