steering wheel ?
Old Feb 5, 2010 | 06:49 AM
64 hi-boy's Avatar
64 hi-boy
steering wheel ?
This the best site i've ever seen!. I have a 64 4x4 and I what to put a smaller steering wheel on it like maybe an f-100 it turns real easy, will that work Thanks Rod
Old Feb 5, 2010 | 07:44 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Are you planning on installing P/S?
If not...you do not want to change to a smaller steering wheel.
With manual steering & 4WD, if you install a smaller diameter steering wheel, it will take one hell of a lot more effort to steer it.
This is why Ford used an 18" diameter 4 spoke steering wheel on 4WD's, a 17" diameter 3 spoke steering wheel on 2WD's.
In this case...size does matter!
Old Feb 5, 2010 | 08:38 AM
64 hi-boy's Avatar
64 hi-boy
Thanks for the info n.d., So it would be better to stay out of the kitchen than change the wheel . Thanks again, Rod
Old Feb 5, 2010 | 10:51 AM
garbz2's Avatar
garbz2
Plus the regular 2 wheel drive wheels are too small a center diameter for the column.
You can change the column to a 61 to 64 2 wheel drive and use the smaller wheel. But as Bill stated the effort is greatly increased.
Garbz
PinkyRingz
Jan 4, 2020 12:42 PM
michael a
1947 and Older Ford Trucks
Dec 31, 2016 10:22 AM
elgemcdlf
18
Jan 25, 2013 12:59 PM
weekendwarriorfsw32
Sep 28, 2009 03:45 PM
