Hello and E4OD Help
Old Feb 4, 2010 | 07:34 PM
Filmy's Avatar
Filmy
Hello and E4OD Help
Hi. Glad I found FTE because it seems busier than that other site I had been hanging around on.
My truck: 1993 F-150, 4X4, 5.8L, E4OD, longbed, slight suspension lift. This is my problem...
The truck is a recent purchase with the PO claiming engine and trans rebuild 30K ago, including hi-comp pistons, hi-vol oil pump, etc. No paperwork to show for all of this, but I do believe him. On the way home from picking it up (long drive, highway 75mph, cruise on, OD on) I had a sudden loss of power. Looked down at the gauges and the temp was about 7/8 and the MIL came on. Cruise didn't let go until the truck slowed to about 45.
So I pull to side of the highway, smack it into neutral and the temp comes back down immediately and the MIL goes back off - in other words back to normal operation (but with a new, slight tick coming from the engine).
Back on the road five minutes or so later - same thing, but I didn't have the CC on. This time, I pulled over and the tick became a knock. I decided to limp the remaining 5 hours home, but I did it without the OD on, which seemed to cause the problem.
The symptoms seemed like/as if the trans or driveline bound up and the TCC didn't unlock from the flywheel (and since I didn't use the brakes, the CC didn't disconnect either), causing serious detonation and damaging the engine, which has now been rebuilt and I saw the pistons - 5 broken on top, etc.
Trans fluid is burnt, but not low. I haven't dropped the pan yet, but is this a common occurrence? Could the trans stay locked to the engine enough to do damage? I know I need to drop the pan and see if there's a bunch of crap in there (steels and clutch material) and I'll likely do a full fluid change. What could have caused this? One more thing: front hubs were locked (don't know why - again, PO...), but not the T-case, so that didn't affect anything.
Second question: since I'd like to put in a shift kit when I open it up, will I be able to tell from just looking at the valve body if there's a S/K installed?
Last thing: if anyone in the SoCal area has a good E4OD (4X4) or a good source for one, I'm interested.
Old Feb 5, 2010 | 12:15 PM
Lazy K's Avatar
Lazy K
Not an expert but my thoughts are these. I can think of no way the torque staying locked on the highway could cause the problem. It`s like saying that with a manual you did not depress the clutch pedal while driving.
What did the codes say?
Good idea to drop the trans pan and have a look, need to do that anyway to change the discolored fluid. Drain the torque at the same time.
Old Feb 5, 2010 | 05:34 PM
rla2005's Avatar
rla2005
I agree with this response. No way a locked converter is going to ruin an engine.
How to tell if a shift kit is installed? Not really sure on an E4OD. I would purchase a valvebody from thePunisher. Topnotch, quality parts by someone who stands behind their products.
redman84
May 3, 2010 02:27 PM
manofsteel113579
Apr 24, 2010 11:06 AM
SteveGB
Nov 24, 2007 02:52 PM
hammlm
Jul 9, 2007 07:18 AM
1pump
Feb 24, 2003 02:10 PM
