Sponsored by: Auxito
Bolt Pattern
Old Feb 4, 2010 | 06:00 PM
bronk n blue's Avatar
bronk n blue
Bolt Pattern
Sorry so short, only have a min. Will the rims off a 90 4x4 Bronco fit on a 90 F150 4x4 ? Thanks in advance!!!
Old Feb 4, 2010 | 06:06 PM
steve(ill)'s Avatar
steve(ill)
i doubt it. the Bronco is the small truck and should have a 4-1/2 inch circle. The F150 should be a big axle and measure 5.5 inch
Old Feb 4, 2010 | 08:03 PM
thecardoc's Avatar
thecardoc
Yes they will bolt right on . Just about everything from the doors forward will direct interchange between these trucks. They both have a 5.5 inch x5 bolt pattern.
Old Feb 4, 2010 | 08:24 PM
steve(ill)'s Avatar
steve(ill)
oops.. ii though you were talking about a small Bronco like the Ranger. If your talking about the big truck, then yes, doc is correct.. Im not sure when the smaller Bronco II was even made, i just thought "small" when i saw the post... sorry for the confusion.
