Drop the pan and figure out which one you need to change. Remove the e clip ( I have used a pocket knife before) to remove the clip and slide the solenoid out. Its pretty simple.
I had a link to a great write up on thedieselgarage forum, but when they got hacked the links changed. I meant to post one that I thought that I had corrected - NOT!
I will look some more .....
Mark, when you find the link...you think you can get it put into the Tech folder?
