Transfer case swap
Old Jul 16, 1999 | 01:51 PM
Miketnf150's Avatar
Miketnf150
Transfer case swap
<center><font size="1" color="#ff0000">LAST EDITED ON Jul-19-99 AT 06:35&nbsp;AM (EST)</font></center>
I have a 79 F-150 w/ 300 6cyl., NP432 4 speed Transmissino, and a NP205 (196 Gear Ratio) Transfer case. I also have a wrecked 79 with a C6, NP203 (201 Gear ratio) Transfer case. I was wondering if I could swap out the NP205 for the NP203. I have all the driveline parts from the 203 including axles, driveshafts, etc. I just want to know if they will swap and if the different gear ratios is going to be a problem. I am also going to swap the 6 for a 351m/400 soon. So let me know if that will be a problem as well. Thanks a bunch for your alls input. I enjoy coming to the BBS and seeing what you all are talking about..... THANKS!!!!
Old Jul 16, 1999 | 08:10 PM
jowilker's Avatar
jowilker
Transfer case swap
Mike you should be able to swap like parts, with no problems, as for the engine swap not sure. The 351m is a different family, better check farther on that one. The 300,302,351W, I know are the same. The bellhousing is where the difference would be.
Good Luck,
John
Old Jul 17, 1999 | 05:40 PM
Randy's Avatar
Randy
Transfer case swap
Aaron Kendall
Apr 23, 2017 08:27 PM
Kyle Wood
Oct 19, 2016 11:28 PM
nsboyd1210
WTB - Parts & other
Sep 18, 2015 09:14 PM
Pipelinewelder20
15
Oct 2, 2014 03:56 PM
longhorns13
Sep 30, 2009 09:12 PM
