AC Compressor siezed.
Old Feb 4, 2010 | 02:42 AM
Thudpucker's Avatar
Thudpucker
Cool AC Compressor siezed.
97 F-150/4.6/4X4
My AC Compressor is seized. I finally figured out the previous owner had cheated the Switch and the AC pump was engaged all the time. 170K miles now.
So it finally seized. Its stuck solid. I can just reach the pulley with my finger tips and there is no play at all in that pulley.
I haven't taken it off yet. Too difficult to do in this cold weather.
Hazard a guess for me.
Will I need to replace this pump, or can I just replace the bearings myself?
What seizes? The pump impellers, vanes or pistons? Bearings?
Can I get this one apart?
Old Feb 5, 2010 | 01:12 PM
lsrx101's Avatar
lsrx101
If the clutch was bypassed to run full time, the compressor itself is most likely seized. It will have very likely sent debris through the entire system and you'll need to replace most of the underhood components (compressor, condenser, and accumulator) The condenser can't be reliably flushed due to it's internal design. Some parts can be replaced with known-good used parts.
BTW, the compressor can't be repaired DIY.
A known good used condenser will work fine, along with a new accumulator and a quality new or reman compressor. You will need to solvent flush the rest of the system. If the compressor discharge line has a muffler (inline "can") it will also need to be replaced, a good used line will work.
Remove the belt and see if you can turn the pulley. If so, try and turn the clutch face.
If the pulley is frozen but the clutch turns freely, you can replace the clutch/pulley assembly.
If the clutch won't turn, the compressor is seized internally.
Old Feb 5, 2010 | 05:04 PM
Thudpucker's Avatar
Thudpucker
Thanks LS.
A very comprehensive reply.
When it warms up a bit....
I'm in School now and way behind them dang kids.
That pickup will just sit in the barn till the weather warms up.
PS: I used to go to Tech School in Miamisburg and when I learned to fly I'd land at Morain and South Dayton.
Dick
marcogyver
Sep 10, 2016 08:33 PM
Blockfort
Aug 30, 2016 12:07 AM
centquinze
Jun 8, 2015 12:29 PM
Rangerdude1
1983 - 2012 Ranger & B-Series
Apr 6, 2015 09:56 PM
Cor
2004 - 2008 F150
Mar 31, 2015 03:29 AM
