Looking for help
Old Jul 22, 1999 | 08:13 PM
cliff hawkins
Guest
Posts: n/a
Looking for help
Hi all, i just bought a 351w out of a 73 torino, i am seeking info on what i need to do to drop the engine in a 66 f100. I have a 240 in it right now with a straight 6 on the floor. I want to go automatic, how hard is the project going to be and what do i need to do to adapt the motor and transmission? Please Help
Old Jul 23, 1999 | 05:58 AM
StockMan's Avatar
StockMan
Looking for help
<center><font size="1" color="#ff0000">LAST EDITED ON Jul-23-99 AT 07:00&nbsp;AM (EST)</font></center>
The easiest way to do this would be to buy a later model truck with a 351/400 and an auto trans. It will have all of the items you will need for the swap. Look for something in the 73-79 range. The only part I am not real sure about is whether the later model pedal assembly will fit your 66. Worse case is that you will have to get that item seperately. Hope this helps.
Stock Man
1967 Galaxie 500 Convertible (I need factory rims)
1967 F-250 FE 390 4wd
<a href="http://www.hometown.aol.com/tbeeee">http://www.hometown.aol.com/tbeeee</a>
Old Jul 23, 1999 | 07:32 AM
slik's Avatar
slik
Looking for help
Get a PAW catalog (about 3 inches thick), they have a couple of pages of engine and tranny mounts for conversions in older trucks plus they have a ton of other automotive stuff.
Slik
Old Jul 26, 1999 | 01:16 PM
Jeff's Avatar
Jeff
Looking for help
Whatever you do, replace the timing chain while it easy to get to. After that many years the nylon breaks away from the teeth and causes slippage. I'm in the middle of removing heads with bent valves from a '70 351W slipping a tooth or two. It never broke the chain.
Old Jul 26, 1999 | 01:43 PM
jesse's Avatar
jesse
Looking for help
