Sponsored by: Real Truck
Could these 4 wires...
Old Feb 4, 2010 | 09:18 AM
bpounds's Avatar
bpounds
Originally Posted by wk4bg8s
Somewhere under the dash, on the drivers side, there are 4 relays that I can connect to. I have a feeling from the description that there is not an actual wire supplied by Ford, I supply that myself when connecting up wahtever it is I connect
Unless you someday have a failed relay, there is no reason for you to need access to the relays. Here is a document that shows where everything is:
https://www.fleet.ford.com/truckbbas/non-html/Q157.pdf
Ford does supply stub wires for you to connect your applicances. They are on the drivers side, under the steering column. This document explains how to find and utilize the upfitter stub wires:
https://www.fleet.ford.com/truckbbas...tml/Q117R1.pdf
Old Feb 4, 2010 | 10:35 AM
TexasRebel's Avatar
TexasRebel
There is no fuse block there in '08.
The relays moved to the drivers side in '08 (if they had previously been on the passenger side) the first document that bill linked even explains that...
Old Feb 4, 2010 | 10:46 AM
bpounds's Avatar
bpounds
I guess you're right, although the drawing in that document sure makes it look like something different. I edited my post above to avoid confusing anyone in the future. Best I just let the document speak for itself. Thanks for correcting me.
Old Feb 4, 2010 | 10:55 AM
TexasRebel's Avatar
TexasRebel
I got confused by the picture too...
the illustration in the document is from the point of view of the transmission... looking at the driver's seat from somewhere near the gas pedal...
OGTerror
Offroad & 4x4
37
Apr 29, 2011 07:23 PM
BigF350
Mar 17, 2010 10:52 AM
BigF350
General Automotive Discussion
Jan 25, 2010 08:39 PM
OGTerror
Offroad & 4x4
Sep 3, 2009 03:23 PM
