new guy
Old Feb 3, 2010 | 12:24 PM
chicagodragon's Avatar
chicagodragon
new guy
Hello, iam new to this side ofFTE. iam looking into a 1997 expo with 180k on the clock for $1000.00. is it worth it? what should i look for as far as major problems go? it is owned by by neighbor, so i have known the truck for a while. iam just woundering what to look at and any info would be great, thanks.
Old Feb 3, 2010 | 12:55 PM
Omahastro1's Avatar
Omahastro1
I think the 97's were pretty solid. I think just the usual items on anything. One thing to be aware of is the blend doors. If it has auto temp controls the blend doors can be a problem. If it is a 4 x 4 the shify motor on the tansfer case could be going out and need to be replaced. Don't really hear much on 97's.
Old Feb 3, 2010 | 01:16 PM
chicagodragon
i heard tht the timing chain could be an issue? iam sorry, meant 98
Old Feb 3, 2010 | 06:32 PM
madsonp's Avatar
madsonp
Spark plug blowout issue.
Old Feb 3, 2010 | 08:24 PM
chicagodragon
the threads strip out?
Old Feb 3, 2010 | 08:32 PM
ranchergirl12's Avatar
ranchergirl12
i have the same year and my water pump keeps going out
Old Feb 4, 2010 | 09:52 AM
dirtmonkey11's Avatar
dirtmonkey11
I would check all the usual things that I would look for when buying any used car or truck. The main things i would look for is, has the truck been maintained regularly, how many owners has the truck had. Look for signs of a accident, look for odd paint lines and blends which might mean the truck has had body work at one point. Also check all the engine. if the oil fill cap has white powder or residue on it, don't buy the truck because normally that means there is water in the engine. Also check to see if the 4x4 works if it has it. Check the suspension and tires also, tires are not cheap these days. Also just for piece of mind I would do a CARFAX report on it. As far as any major problems, there aren't that many that come to mind, just the usual stuff for a used car.
Old Feb 5, 2010 | 09:05 PM
madsonp's Avatar
madsonp
Yep, they sure do. They make a thread insert kit for these when it happens. If you do a search you'll find all sorts of info. on the subject.
Old Feb 5, 2010 | 11:56 PM
97ExpGuy's Avatar
97ExpGuy
Originally Posted by dirtmonkey11
if the oil fill cap has white power or residue on it, don't buy the truck
That's right. Don't buy the truck if there is evidence of white power!
Sorry had to do it! I was glancing through the thread, thought I misread your post, but when it turned out that I didn't misread it, I had to quote.
Gave me a good chuckle.
Old Feb 8, 2010 | 11:30 AM
Omahastro1's Avatar
Omahastro1
I could be wrong but I beleive the spark plug blow out is on the 99 and up PPI heads. I thought the 97 and 98 were not as big an issue.
Old Feb 8, 2010 | 02:49 PM
chicagodragon
other than making sure my truck is not racist, just lok for the normal used car stuff. nothing special?
Old Feb 9, 2010 | 07:30 AM
c_hohensee's Avatar
c_hohensee
I blew a plug on my 98 so it does happen on 98's as well.
Old Feb 9, 2010 | 09:44 AM
dirtmonkey11
Sorry guys, I meant white powder, not white power lol
lendog
Apr 13, 2016 05:23 PM
al0311
Aug 22, 2015 08:58 PM
new2fordf250
25
Dec 26, 2009 11:56 PM
crapr6
139
Mar 26, 2009 07:45 PM
procharger
Engine Swaps
Aug 8, 2005 12:35 PM
