Manifold testing
Old Aug 3, 1999 | 01:56 PM
jesse's Avatar
jesse
Manifold testing
Does anyone have an idea way to check for a crack in the intake manifold? I have no accessibility to dyes or hitech machinery. The manifold is off the engine. Thanks. Jesse
Old Aug 4, 1999 | 04:42 PM
76highboy's Avatar
76highboy
Manifold testing
Cover the port holes with duct tape or that wide clear packing tape. Then fill up the manifold with water and check for leaks. Afterwards, flush it with the hottest water you can get and bake it out in the oven to make sure it is good and dry. You don't want any rust in there.
I haven't tried it, but it seems the easiest low tech way to check for leaks.
Otherwise, you're looking having a machine shop magnaflux it (if it's a cast iron manifold).
Old Aug 4, 1999 | 10:25 PM
Bruce's Avatar
Bruce
Manifold testing
Another way would be to tape-off the carb mounting area and the ports with tape and then use a hand vacuum pump with a vacuum gage on it.
Give it some vacuum and see if it looses any. If it does then try to locate it.
Bruce
Old Aug 5, 1999 | 05:13 AM
jowilker's Avatar
jowilker
Manifold testing
Jesse73iditurbo
Dec 21, 2016 11:57 AM
Jess51
May 21, 2015 11:37 AM
thunderb
Oct 9, 2006 12:58 PM
jesse460
18
Mar 4, 2003 06:32 PM
jesse
Bronco II
Mar 3, 2002 08:08 PM
