Iam new to FTE ,I bought 65 f 100 long bed i plan on restoring .The truck is in good condition for its age cab mounts,floor,fenders ,hood ,chassis.the bed is rough side caved in floor rotted out . Question for Number Dummie? Trying to find out how "original"the truck is :F10DK613983 WB 129 Color JM Model f100 Body E81 Trans G Axle 07 DSO 54 172 hp@4000 rpm gold valve covers There are no cooling lines to the radiator but, there is a hose running from lower radiator hose to transmission then back to block .Did they cool transmission this way back then? thanks for help
Hey seen the breakdown of his truck and thought that was cool was wondering if you could do mine just interested how much has changed in the last 45 or so years just purchased a 1965 (according to the title) with a 64 grill Ford f-250 4x4 thanks, Rob F26DK686223
F25 = F250 2WD
D = 352 2V
K = Kansas City Assembly Plant
686223 = 1965, assembled May 1965.
The codes for the COLOR, MODEL, BODY and etc will be found on the Warranty Plate, located on the left door face below the latch.
