Another wiring question...
Old Feb 2, 2010 | 08:25 AM
Ammoyankee's Avatar
Ammoyankee
I know many different wing questions have been posed before, but here is mine...
I have an 86 F150 and it had the electronic AM/FM cassette player which had a short, it had the two receptacle hookups. I installed a new Kenwood CD player and I figured out the speaker wiring easily and thought I had the power memory hookups licked too but the stereo will not maintain memory. I hooked the battery wire from the Kenwood to the yellow/black wire from truck harness and the ignition wire to the green and purple (I think) wire. Where did I screw up? I am "electronically challenged" and any help is appreciated! There is also an blue/red wire which I didn't use.
Old Feb 2, 2010 | 10:13 AM
bghnkinf250's Avatar
bghnkinf250
I thought the red and blue wire played into it. Your best bet would be to probe each one with a test light or multi meter. Constand voltage with the key off will be the memory, and the voltage with the key on only will be wour switched power.
If I remember, it was hard to find the right schematic on the internet.
Old Feb 2, 2010 | 12:34 PM
Ammoyankee's Avatar
Ammoyankee
Thanks...
Thanks for the reply, I had wires reversed, all is good now~
Old Feb 2, 2010 | 05:48 PM
bghnkinf250
I am glad to hear it.
Old Feb 2, 2010 | 06:45 PM
Fordzilla80's Avatar
Fordzilla80
Lt Blue/Red is for illumination(lighting).It runs throughout the truck to power other accessories like the ashtray light and courtesy lamps IIRC.
Old Feb 2, 2010 | 06:56 PM
ri_truck_guy's Avatar
ri_truck_guy
One thing I do with every truck I get is to pick up a secondary fuse box. You can usually get a six circuit box from a parts store for about $10. I just wire it straight to the battery and install it behind the brake pedal. That way I have an easily accessible constant 12 volt source that I can wire all kinds of accessories too. Each accessory is individually fused and it doesn't overtax any existing truck circuits.
Old Feb 3, 2010 | 04:34 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
The Light Blue/Red stripe wire is just for Radio Dial illumination only. Not used on a aftermarket radio.
Here are the Factory schematics...
1980-1982: Radio and CB Radio Power and speaker Wiring diagram.
http://i447.photobucket.com/albums/q...l/scan0004.jpg
1980-1986: Windshield Wipers and Radio Dial Illumination Diagram
http://i447.photobucket.com/albums/q...scan0003-1.jpg
1983-1984: Radio Power and Speaker Wiring diagram
http://i447.photobucket.com/albums/q...l/scan0001.jpg
1985-1986: Radio Power and Speaker Wiring Diagram
http://i447.photobucket.com/albums/qq194/darosamarciel/scan0002-6.jpg
glass_joe099
28
Feb 6, 2026 10:43 PM
norman2012
Jul 24, 2016 11:12 AM
MBBFord
2004 - 2008 F150
Nov 12, 2014 04:14 AM
bwolgie
Nov 3, 2014 08:00 AM
powerstroker100
Aug 7, 2010 10:54 PM
