Sponsored by: Real Truck
More 4wd Issues
Old Feb 2, 2010 | 08:13 AM
mstiles19's Avatar
mstiles19
More 4wd Issues
Is my hub bad?
I have warn manual hubs and the passenger side is will vibrate when engaged 4WD and traveling over 5mph. It also vibrates if the hub is engaged and the transfer case is not and it also it if the transfer case is engaged and the hub is not. When everything is disengaged and free there is no problems at all
what do you guys think?
Old Feb 2, 2010 | 08:34 AM
senix's Avatar
senix
I certainly think there is an issue all right.
did you jack it up and see if there is play. I think you need to take it off and see if those needle bearing are shot.
Old Feb 3, 2010 | 01:27 PM
mstiles19's Avatar
mstiles19
how do i check the needle bearing? i would like to fix this before the predicted big snow storm this weekend.
Old Feb 3, 2010 | 01:32 PM
senix's Avatar
senix
Here is a useful link to do some maint. on it.:
Welcome to guzzle's 4x4 Needle Bearing Maintenance Web Page
Let us know.
Old Feb 3, 2010 | 02:09 PM
mstiles19's Avatar
mstiles19
man this is gonna be a pain. if i pull my truck apart how am i gonna drive to the parts store.
Old Feb 3, 2010 | 02:10 PM
senix's Avatar
senix
yeah, I know what you mean. I have a napa within walking distance if I had to.
Old Feb 3, 2010 | 02:18 PM
mstiles19's Avatar
mstiles19
i am willing to bet that i am gonna have to replace the axle shaft. i had the other side done about a year ago and i don't think they have ever been greased in 170000 miles
Old Feb 3, 2010 | 03:00 PM
senix's Avatar
senix
every 30K they should be done...mine are a bit over due but it has been so cold out. trying to hold on till april.
Old Feb 3, 2010 | 03:07 PM
mstiles19's Avatar
mstiles19
ha tell me about it. I am gonna have to do this in my snowy muddy driveway. Do you have any idea how hard is it to change the outer shaft? or if i need any special tools?
Old Feb 3, 2010 | 04:16 PM
senix's Avatar
senix
never done that myself, but check out this guys site:POWERSTROKEHELP.COM - The Information Source for Ford Power Stroke Diesel Owners
He covers that.
Old Feb 3, 2010 | 06:22 PM
mstiles19's Avatar
mstiles19
so is the hub the same thing as the needle bearing?
Old Feb 3, 2010 | 07:05 PM
senix's Avatar
senix
no, but that needs to come off before you can get the hub off. Then the axle will come out.
Old Feb 10, 2010 | 06:08 PM
mstiles19's Avatar
mstiles19
ok i know it has been a while but this weather here is crazy! I pulled it apart and the needle bearing looked fine. it still had grease on it and everything so i took it to my local shop since i knew i needed my 4wd for these storms. They checked it out and said that it was actually my drive shaft making the noise and that they would need to pull it and send it out to be fixed.
fortunatly they said it would be fine to use in the snow. My house sits in the middle of a 200 acre field so the snow drifts here are insane
beefey
Jan 30, 2014 10:42 PM
radmacks
Dec 30, 2011 08:29 PM
pistolhunter
Jan 28, 2010 11:55 PM
seayya
Feb 15, 2008 10:47 AM
MBBCop
Feb 12, 2007 02:03 AM
