Does your 4wd engage when you hit 50mph
I have a crazy rattling vibration when I hit 50mph. I jacked it up and put it on stands and got my buddy to bring it up to 50. My front output shaft starts spinning and my transfer case starts shaking like crazy.
My question is, is it normal for the transfer case to engage like that at highway speeds? I have a post going in the Excursion section but the average is 100 visitors vs 400 here and this problem is driving me crazy.
I have an Electronic transfer case with Manual Warn premium hubs that have been tested and are functioning correctly. The transfer case engages and disengages as it should and does not vibrate at all when engaged up to 50 mph.
That is not normal at all. Can you see the solenoid on the transfer case engage when the output shaft starts spinning? Or does it engage right away and then take a while for the shaft to start to spin?
Also, have you checked the transfer case fluid, ensure the transfer case solenoid and mechanism are lubricated, etc.?
I will be checking the solenoid on Monday, what should I lubricate it with wd40 break clean? I so far have checked it by engaging and disengaging the 4wd and it seemed to work fine. I'm just trying to wrap my mind around how the solenoid would cause this, maybe its not moving the fork all the way back/forward and its drag?
There is no way to know until it comes apart and gets inspected.
If you think it might have something to do with the electronic control mechanisms, unplug the wiring harnesses from the transfer case and see if it still does it. If it does, it's mechanical and the transfer case is going to have to come out and either be replaced or repaired.
I would lean towards an internal type issue, the bearings sound about right.
I have also seen the linkage the transfer case stick. The solenoid motor has pressure on the linkage, vibration gives it the additional motivation it needs to move, and then it vibrates the final travel to engage the transfer case. This would be obvious by looking at it. If you already have full travel then it is not something as simple as the linkage.
i have a 2008 450 dulley, 4wheel started trying to cut in at highway speeds,tried disconexing cable at transfer case no help. paid ford 400 dollars to find out the problem. they said it was the 4wheel drive moudle. it was behind the glovebox on right side. disconnected it no futher problems for 4 months, no 4wheeldrive now. approx 200 for part little over 100 to reprogram. may fix next year. good luck.
On early model trucks (like yours) it is controlled by the GEM. In 2003 or so, the GEM went away and was replaced with individual modules, including the 4WD control module.
That is why I suggested disconnecting the connectors from the shift motor. That will render the shift motor inoperative and, if the problem continues, eliminate all of the electronics as a possible problem.
$Simpleman76
04-14-2007 11:50 PM
Katmandu
11-02-2005 09:46 PM
