front spring removal
Old Feb 2, 2010 | 12:11 PM
lew52's Avatar
lew52
Yeah take an asortment of 1/2 in extensions & ratchet & breaker bar & 1 1/8 socket & wrench & swivel , not sure about the 4wd never did one but on a 2wd you can get the the bottom bolt thru the top of the spring once you get the top out , i remove the brake calliper & unhook shock & unhook the sway bar if it has one , An impact gun is nice to have if you have a way to use a compresser...Lew
Old Feb 2, 2010 | 12:15 PM
lew52's Avatar
lew52
Oh im not 100% sure on the 1 1/8th but that sounds right ...
Old Feb 2, 2010 | 12:23 PM
andym's Avatar
andym
I'm almost sure it's 1 1/8" but I don't know if an F-250 or F-350 wouldn't have a bigger nut.
Old Feb 2, 2010 | 02:57 PM
White 97 xlt's Avatar
White 97 xlt
For what it is worth, I just went out and checked my '97 F-250 HD (Old Body style) and it is 1 1/8... Can't help with any other year or F-series,, sorry..
Old Feb 2, 2010 | 08:04 PM
mattystowe's Avatar
mattystowe
Thanks for the indirect help guys..I've been looking at my new coils in my kitchen for about a week, some guy telling me 350 to out them in.. F that. I got a manual but it always pays to check what you all are saying. I gotta get me some pb blaster im on cape cod in ma salt haven it's gonna be a b#$%h. thanks for the cutting the wrench head off idea im sure ill be usng that along with some heat.
Old Feb 2, 2010 | 11:31 PM
TexasGuy001's Avatar
TexasGuy001
I agree about the bottom retaining nut being a chore by itself. I just looked to make sure and the wrench I have for doing that is 1 1/8.
Old Feb 3, 2010 | 11:52 AM
BCHauler's Avatar
BCHauler
I just used a socket wrench and an extension for the bottom retaining nut.
Old Feb 4, 2010 | 06:46 AM
TexasGuy001
I used a combination of a breaker bar and a box end wrench, since the ratchet head is too big to get between the coils. I don't have an extension that long, but it would have been nice.
Old Feb 4, 2010 | 10:49 PM
ngagnej's Avatar
ngagnej
I just did this job today (springs/shocks) and I was actually surprised how easy it was, it really was as simple as removing two nuts. The worst part is the lower retainer, used a 1 1/8 wrench and some seafoam with some persuasion and it came loose, but after that the spring literally fell out.
Clear night and day difference, feels like I'm driving a new truck!
Old Feb 21, 2010 | 10:31 PM
bigmacmonday's Avatar
bigmacmonday
Originally Posted by TexasGuy001
You should not need a spring compressor. I didn't. I didn't even need one for the leveling springs I used to have.
Use a floor jack under the I beam and radius arm. Jack it up and put a jackstand under the frame. Then after the lower shock bolt is removed and the spring retainers top and bottom are removed, the suspension should drop down far enough for the spring to fall out. I think with the leveling coils I had to push down on the suspension a little.
What are you replacing your springs with, new ones or taller ones?
I think the lower spring retaining nut is 1 1/8 inch.
I am thinking of replacing them with Moog CC844 or CC844S as I understand they will give me a lift right
Old Feb 21, 2010 | 10:40 PM
BCHauler's Avatar
BCHauler
Yup, they will give you some lift.
Old Feb 21, 2010 | 10:48 PM
truckrider814's Avatar
truckrider814
Ok to ask but which would be better and keep price in mind get some 250/350 springs outta a pick n pull or the Moog CC844 or CC844S?
Kyle
Old Feb 21, 2010 | 11:02 PM
  #28
bigmacmonday
Kyle
Price for the moogs $72.99 for both at rockauto.com and the junkyard would prob be like $50 for both so a pick n pull would be cheaper but... the moogs are new and way better. worth the extra 20 bucks or so.
Old Feb 21, 2010 | 11:22 PM
  #29
bigmacmonday
How do you plan on getting it aligned? Are you going to get the correct camber bushings to correct the alignment? Are you going to install them yourself or have a shop do it? Have you found a shop that knows how to install the correct bushings and align it?
You should have good answers to all of these questions before you start working on this project.
I thought it would just be a spring swap and im done... What all do i need in addition to the moog springs? I am doing this job myself. Instead of using the junkyard springs though I decided to buy some moogs.
Old Feb 22, 2010 | 06:37 AM
  #30
TexasGuy001
From what I have seen from others results those springs should give the front of the truck a little lift.
You will need to get an alignment afterwards. You may also want/need slightly longer shocks, but probably not.
