Power steering pump pulley
Old Feb 1, 2010 | 04:54 PM
rdw516's Avatar
rdw516
Unhappy Power steering pump pulley
Does anyone know where I can purchase a METAL power steering pump pulley for a '92 F150 4.9L. The one for the 5.0 is the same pulley as Napa does not list one for the 4.9L. The OEM pulley is chicken feces plastic and breaks if you look at too hard. (Serpintine belt came off today due to a chunk of ice coming up from the road and the tensioner bumped the pulley and broke the P.O.S.
I am looking for a metal one to replace it with. I hope someone can help me!
Old Feb 1, 2010 | 05:27 PM
Hitokori's Avatar
Hitokori
i dont think they make metal ones.... all the ones i have seen have been the composit ones and they hold up fine and dont break that often... $10 each....
get a metal one off a GM car or truck
Old Feb 1, 2010 | 08:32 PM
Ohio Ford Farm's Avatar
Ohio Ford Farm
I did not know there was a difference in the pulley between the motors?
Old Feb 1, 2010 | 08:38 PM
dustybumpers's Avatar
dustybumpers
my 89 4.9 4x4 f250 is metal from the factory, I don't know if the 4x4 f250 part makes a difference or not. try the junk yard
Old Feb 5, 2010 | 07:22 PM
Poidexster460's Avatar
Poidexster460
Werid, yah my 300 is Metal one and my 460 is a Plasic pully. Just like said above a wreaking yard fershur.
Old Feb 5, 2010 | 08:47 PM
tbenks's Avatar
tbenks
on the topic off power steering pump pulleys, mine has a little bit off play in it, it dosnt wobble but if you pull on it it slides forward about 1/4 inch? is there a way to tighten it?
Old Feb 5, 2010 | 10:16 PM
Poidexster460
No, they are held in place by Compression like all as far as Im conserned. Sounds like the pully has gone bad
Old Feb 6, 2010 | 09:15 AM
EPNCSU2006's Avatar
EPNCSU2006
There is some slop in the pump internals that allows for some axial movement of the pulley and shaft. The pump on my truck does the same thing, but 1/4 inch seems excessive. The only way to know for sure is to disassemble the pump. The pulley is pressed onto the shaft, so if the pulley moves any on the shaft, it will probably not stop at 1/4 inch, but rather slip all the way off.
tweedking
Jan 15, 2017 08:22 PM
Jjona5
Nov 3, 2016 09:27 PM
warren561
Dec 16, 2013 10:10 AM
Marky48170
WTB - Parts & other
Jul 28, 2012 07:57 AM
greasemanicure
Mar 27, 2012 10:03 PM
