What causes this?
Old Feb 1, 2010 | 04:12 PM
BCHauler's Avatar
BCHauler
What causes this?
We're going on a trip next weekend through the mountains and I'm doing some tune up work on the truck prior to the trip, as it was this same trip last year that spelled the end for my previous motor. Anyway, I replaced my fan clutch and decided to reroute some of my spark plug wires after reading how common crossfire is on these motors. I have a stumble that sometimes appears under heavy load at lower rpms 1500-1800 (climbing a hill at freeway speeds for example). Anyway, while rerouting the plugs I noticed that the cap felt loose. I popped it off and all of the terminals had a buildup of black carbon, as did both ends of the rotor. I cleaned them off with some sand paper and reinstalled it. Cap feels tighter but still moves a bit.
I've had greyish carbon buildup before but never black. What is the difference? fyi - the current cap and rotor were installed new with my motor in the spring and have maybe 5000 km on them.
tia
Old Feb 1, 2010 | 04:29 PM
Hitokori's Avatar
Hitokori
oxidation <---- think thats spelled right... its just a different color corotion... sometimes u get green in them too
Old Feb 1, 2010 | 05:08 PM
lew52's Avatar
lew52
What cap & rotor did you use...Lew
Old Feb 1, 2010 | 07:15 PM
BCHauler's Avatar
BCHauler
Blue streak, I think, maybe Autolite. Plugs are Autolite. I'm thinking about getting a Motorcraft cap and rotor.
Any thoughts on what caused the black carbon buildup?
Old Feb 1, 2010 | 07:19 PM
Linemo's Avatar
Linemo
I kinda wonder if its not moisture cause you see it more in the fall to winter months did the cap you used have the vent on top?
Old Feb 1, 2010 | 08:00 PM
BCHauler's Avatar
BCHauler
It has a little black cap on it. Am I supposed to leave that off?
Old Feb 1, 2010 | 09:01 PM
Old93junk's Avatar
Old93junk
Pretty common up here in the wet Pacific Northwest, lots of condensation too.......clean it up with some electrical contact cleaner and monitor how soon it builds back up.......Probably wont see it once summer comes.
cdawley4
Feb 15, 2011 08:47 AM
cadillacmob
56
Feb 11, 2011 09:00 AM
ac700wildcat
Aug 13, 2010 09:44 PM
cracker500
2004 - 2008 F150
13
Aug 3, 2008 09:07 PM
Kevinjh
May 1, 2008 12:36 AM
