my ttb has a 6 inch skyjacker and 2inch add a leafs and let me tell you it was a bitch getting it done. took me and a buddy 14 hours and had to fab the lift a bit to make it work. i have pics of the installation if you wanna see anything
go to shop that makes, springs, i put 3 in blocks in back, $30. spring shop leveled her off in front $225.--- done --didn't even mess with the steering
Might be a little sensitive on that subject yotee? Nice pics to prove your point though.
not sensitive, i just get annoyed every time i see a post about lifting a truck, some one always chimes in with the "lifted trucks are worthless for towing". the first pic was with an idi f250 on the trailer, 100 mile trip and some good hills to pull. what you can't see is the bed full af crap that came with the truck. that trailer and truck weighed over 10k
the other 2 pics were from trips to the rubicon. if you google ice house rd. in ca or 38.769376,-120.447321 on google maps, it winds and climbs 2000FT in a matter of miles (7.2 miles) and it tows just fine.
Come on over and try our city streets at 30% plus.
That 2000 feet vertical would fit in one mile of road.
US 33 East from Elkins has five mountains with 4 to 6 mile stretches of 12% grades, and that is a main highway east and west in W.Va.
Wonder why they have four tractor trailers over the side of one of the mountains tonight with the snow.
i was wandering when you woul chime in
i am not trying to compete for grades, for almost all of that you can see hwy 50 directly below you. it is not only the grade but the windy road also. we see a few trucks off the road a year. the point is i lifted truck can tow in those conditions.
A lifted truck can tow Power is still there. Also you have a higher center of gravity,so just know your limitations. Another thing that limits your load capability is steeper drive line angles, and then you are more suceptible to axle wrap. So while you can tow you just cant tow as much on the same amount of broken parts lol.
with the correct gearing and set up all you need to concern yourself about is the brakes. but, who tows heavy with out functioning trailer brakes?
edit; i wish i would have taken pics of the 25 ft bumper pull trailer hooked to the tow pig that weighed in at the dump at 17k
I am not arguing that it will not tow. But everything is not equal, your center of gravity has changed no way around it. your driveline angles have changed also no way around it.
The longer your springs are or the taller your blocks are mutleplies the spring wrap. there is a way around this but to me traction bars or ladder bars limit yhe 4 wheeling ability. I run and heavy towed with a highboy without a lot of problems but I can't claim there was no more wear than a normal height pickup. the higher you go the problems compound. All that said I likem lifted, like big tires some things the truck is not equal to but other things low trucks are not equal either it is personal preferance. It's a free country everybody gets to set there rig up to perform the best for their use but every has tradeoffs even slight ones.
