Starter Bendix Problems
Old Sep 14, 2010 | 10:12 AM
redman84's Avatar
redman84
Originally Posted by BigDude97
I took the starter off and the flywheel looked great. The bendix gear showed some wear, but I need to find out what was going on. I pulled the transmission back and took the ring gear/flywheel off and it had 3 worn spots on it where there were no teeth. I replaced the flywheel and put another starter on and now everything is perfect. I have another problem I can't figure out. I had to replace the fuel sending unit on the front tank because it would not regester. Now it has quit working again. You ever heard of this happening?
What did you do to get at the top of that tank? Drop the tank or pull the bed?
Old Sep 14, 2010 | 02:24 PM
MONAVIERONJON's Avatar
MONAVIERONJON
X2,most significantly would be the ground wire concern
Old Sep 14, 2010 | 03:57 PM
97250hd-earl's Avatar
97250hd-earl
or the float bulb has a pin hole leak, it happend to me on a new one.
Old Sep 14, 2010 | 05:37 PM
cecil rauch's Avatar
cecil rauch
same problem except when starter tried to engauge big screetch. Flywheel has 4 bad spots with worn teeth.
Also I went to an electric motor repair shop and started talking about the " bendix ", he about had a fit, bendix is only a name brand that happens to make most of the old school starter DRIVES. He had to inform me that Bendix also made many other parts! But he wasn't A hole about it. Took my starter apart look at everything put back together with no new parts and said that wasn't the issue. No charge!!!
Old Sep 14, 2010 | 08:10 PM
MONAVIERONJON
As for the tank,it drops and is easier when empty
Old Sep 15, 2010 | 06:10 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
My rear tank does this and I'm trying to recall what it is. Something like if the gauge drops to E then it's a bad power wire/connection, if it goes past Full it's a bad ground. Or vice versa, I can't remember. If it's just stuck at E and wiggling the wires don't make it move at all it could also be a pinhole in the float, as mentioned, and the float sank. I've been there, too.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
obscurity
25
Dec 19, 2019 02:35 PM
cjben
Mar 16, 2016 03:54 PM
Greg Castro
Mar 10, 2012 06:39 PM
HankR1966
Feb 7, 2012 08:17 AM
hav24wheel
Jan 5, 2010 10:24 AM
