Transmission suggestions
My question is, what transmission(s) would bolt up? I came across a guy that I bought a hood off of that also had a C6 with the torque converter for $100 so I bought just because it was a good deal, thinking if I couldn't use it, at least I can maybe re-sell for a couple extra bucks. I am not sure what it came off of though, would that bolt on to my 6cyl? its probably too much transmission, but thats why I am looking from some help out here.
any suggestions would be appreciated.
Thanks.
-Johnboy
What freeway is it that can you drive on...at over 35 MPH in normal LA LA Land traffic?My question is, what transmission(s) would bolt up? I came across a guy that I bought a hood off of that also had a C6 with the torque converter for $100 so I bought just because it was a good deal, thinking if I couldn't use it, at least I can maybe re-sell for a couple extra bucks. I am not sure what it came off of though, would that bolt on to my 6cyl? its probably too much transmission, but thats why I am looking from some help out here.
It's no fun shifting gears in LA LA Land traffic either. I did it for 44 years in my '65 F100 with its 3 on the tree Borg Warner T-85N O/D.
1965/74 F100/350 240's and 1965/79 F100/350 300's (except 1973/77 F350's) came with C4's, but...
1978 was the first year Ford offered the C6 in an F100/250 with the 300 I-6 as an option (standard equipment in F350's). Everything will bolt up to your 240.
You will have to modify the driveshaft, and you might consider ditching the anemic 240, and instead, going with the 300 at the same time.
I am open to the best setup as far as transmission and AOD is definately an option as well as a bigger motor. but my knowledge about it is limited, hence why I am here.
My main goal for now was to get it on the road and enjoyable to drive first, the 6 is in very good shape after a good tuneup and compression is within a good range, so I would like to salvage it if I could, maybe soup it up in the near future and still get decent gas mileage.
Thanks for all your suggestions, keep them coming.
