f250 Disk brake conversion?!?!?
Old Jan 31, 2010 | 10:49 PM
Juggie's Avatar
Juggie
Hello all, I am having no luck finding a power disk brake conversion kit for my 1963 8 lug f250. Does anyone know if there is a kit out there, or could I possibly put the 63 f100 kit on this truck and go to a 5 lug rotor. I kinda want to go 5 lug anyway because of the wheel selections available. Any thoughts on this? I also want to get a power steering kit for this truck as well but I understand the difficulty in doing this mod to a 63. Basically I want this truck to look original but I also want to drive it daily and power brakes and steering would help in that department. I also want to go with a retro style aluminum wheel in a 18' to 20' size with performance tires instead of the oe wheels I have now. Any advice or suggestions would be greatly appreciated! Thanks Juggie
Old Feb 1, 2010 | 10:51 AM
flipklos's Avatar
flipklos
Try ECI componants. They make a conversion for the solid axle F100s. They might be able to help.
The 250 is fairly heavy frame for the time and wasent as popular as the 100. That was a working truck then and is now. A power booster and a dual circuit master swap may be the best you can muster.
