400 Vacuum Questions
Old Aug 18, 1999 | 07:27 PM
john's Avatar
john
I have a 400 in my 1978 Ranchero GT. On the passenger side of the intake manifold is a plate that contains a small S-shaped tube that provides heat to the choke. Next to it is a piece of metal tubing with a 90 degree bend that is connected to a piece of vacuum tubing. The other end isn't connected to anything. It pulls something like 22mmHG of vacuum at idle. Any ideas where it goes?
Old Aug 19, 1999 | 08:35 AM
Bruce's Avatar
Bruce
I have a '77 Ranchero with a 400M. I just transplanted the engine/trans into a '71 F350. I still have all the vacuum and wiring diagrams and my notes at home. If no one answers you before tomorrow I will let you know.
Bruce
Old Aug 19, 1999 | 02:15 PM
Kikker's Avatar
Kikker
If the air cleaner is original, did you look on the bottom side of it to see if there is a vacuum line hook up? I had 400 Ranchero years ago but,don't remember. The vacuum line may go to the bottom of the air cleaner. If you have an after market air cleaner all you can do is plug it.
Old Aug 20, 1999 | 08:34 AM
Marty's Avatar
Marty
Don't plug it or the choke won't work properly. If you don't have a place on the air cleaner for it, then check the back of the carb. Most Ford 2barrels have a port on the top rear (it sticks through the flat part behind the choke butterfly) hooking it to that would have the same effect as the bottom of the air cleaner.
Old Aug 21, 1999 | 08:47 PM
Bruce's Avatar
Bruce
John:
Marty is right. On my ’77 it hooked to a vacuum port on the underside of the flat part of the 2bbl carb. This port just passes through to the top side of the carb and provides clean air to be sucked in through the choke’s vacuum port.
Good Luck.
Bruce.
Old Aug 22, 1999 | 06:56 PM
Scott's Avatar
Scott
mhwessel
May 19, 2013 03:43 PM
mhwessel
May 18, 2013 08:08 PM
jstaguy24
Apr 13, 2011 07:07 AM
pgw85706
1983 - 2012 Ranger & B-Series
Oct 19, 2009 09:47 AM
bjoern
Jan 11, 2001 11:41 PM
