what is this part
Old Jan 31, 2010 | 01:47 PM
pete315's Avatar
pete315
what is this part
my son's 4.0 97 Explorer has rough idle. check engine light came on. got codes P1151 and P0153. I thought I might have a vacuum leak. when I pulled the top cover off, behind the idle air bypass valve, there is a piece that looks like a small plunger with a wire comes out that goes to a small swivel. this swivel sits on top of a piece on the top intake. when I took cover off, this was disconnected. the swivel was off to the side. what is this piece and what does it do? thanks.
Old Jan 31, 2010 | 06:31 PM
shorod's Avatar
shorod
Any chance you can post a photo of what you're talking about? Sounds a bit like you might be describing the EGR valve, but it wouldn't have a wire coming out of it, just a vacuum line. Or maybe the Throttle Position Sensor, but that would have three wires and would be on the side of the throttle body, not behind the IAC.
-Rod
Old Mar 28, 2010 | 07:45 PM
pete315's Avatar
pete315
I took cover off and that swivel popped off again. the wire is actually a vacuum line with a plunger. when you rev up the engine, vacuum pulls the plunger moving that swivel piece. still have no idea what this part is called or what it's function is. anyone know what it does?
Old Mar 28, 2010 | 09:07 PM
FireMe's Avatar
FireMe
The 4.0 SOHC has a tuned intake system and the part you describe is part of the linkage that actuates the parts inside the intake manifold.
Without that operational, you will have decreased engine performance, but no damage will be caused.
Jay
Old Mar 28, 2010 | 09:35 PM
pete315's Avatar
pete315
I put a piece of metal across the top of that swivel to prevent it from popping off. the cover is holding it tight in place. truck now feels like I have an extra 50 horsepower. I step on the gas and it just takes off. before it was a real dog. I wonder what this piece controls on the intake.
Old Mar 29, 2010 | 04:48 PM
FireMe's Avatar
FireMe
It controls a flapper valve that basically varies the path that the air takes into the cylinder. At low speeds, the air path is long, which tunes the intake to work efficiently at forcing air into the cylinders at that speed. At higher speeds, the valve opens and causes the air to take a "short cut" straight to the intake valve. This reduces friction and allows more airflow and better tuning at high speeds.
This will briefly explain the idea:
Variable length intake manifold - Wikipedia, the free encyclopedia
Old Mar 29, 2010 | 04:59 PM
pete315's Avatar
pete315
thanks for the info.
Old Apr 1, 2010 | 04:22 AM
ukexplorer's Avatar
ukexplorer
This valve opens a port between the two intake plenums at low speed to smooth out running but closes it at high speeds so that each plenum supplies intake air to only three intake ports for increased power. I read that somewhere but can't remember where.
