1966 - 1977 Early Broncos
carb problems? help
Old Jan 31, 2010 | 11:52 AM
1966 roadster's Avatar
1966 roadster
carb problems? help
I have a 1966 EB roadster its all original. 170 cid 6 cyl. 3 on the tree, unmolested.
I was driving it last summer when it started to "chug" or "cut out" only around 3k RPMs it only did it a couple times.
I drove home to let it cool off so I could work on it. when I went out 20min later i looked things over and could not find a problem. I started it back up and now it just idles. As soon as you give it ANY gas is spits and sputters. It will Idle ALL DAY LONG just dont touch the accelerator or it will choke and chug.I have replaced..
FUEL PUMP
FUEL FILTER
DISTRIBUTOR CAP, ROTOR, CONDENSER,POINTS SET @.025
PLUGS, WIRES
COIL
REBUILT THE CARB, NEW DASHPOT,
BATTERY.
I have set the timing at 6 degrees. I have ran out of ideas please help. thanks
Old Jan 31, 2010 | 12:09 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Check the vacuum advance canister and lines to it. That's a Load-a-Matic system I believe that works with a specific carb. Other than that I haven't worked on one of them.
Old Jan 31, 2010 | 01:04 PM
bigsil48's Avatar
bigsil48
yeah, gfw1985 is on the right track. it sounds like the timing isnt advancing. thats just what it sounds like to me.Good luck!
Old Feb 1, 2010 | 11:46 AM
1966 roadster
Ok your talking about the line that runs from the carb to the bottom of the distributor?
its a hard line now which is kind loose. meaning i can just grab the hard line and pull it out without unscrewing it. should I install a rubber line with new fittings?
Thanks for all the advice.
Old Feb 1, 2010 | 12:04 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
I'd say you definatly have a vacuum leak there. Never repaired one of those myself, but you do need to fix it somehow. Maybe someone else will chime in, or post in the 6 cyl. engine forum for a fix. fordsix.com is another good place for help on those distributors.
Old Feb 1, 2010 | 12:10 PM
1966 roadster
vacuum leak?
k thanks i will try there. my 66 mustang has a rubber hose attached to the carb and the bottom of the dizzy. so maybe i will change out the hard line for a rubber one
Old Feb 1, 2010 | 03:53 PM
1966 roadster
rubber hoseiinstalled
so i changed out the hard vacuum line for a rubber one. still no luck. just idle.
I pulled the cap off the distributor and blew into the hose and watched the distributor advance. I'm still at a loss? any other suggestions?
Old Feb 1, 2010 | 08:00 PM
bigsil48's Avatar
bigsil48
check out your carb base gasket, intake gasket, cracked intake around the mateing surface to the head! ?????thats a good one ,but probably something simple. good luck!!
Old Feb 2, 2010 | 12:45 PM
mcdobson's Avatar
mcdobson
Use the good old fashioned vacuum leak detector. A can of carb cleaner. Spray at the carb base etc. If the idle changes you know you found the leak.
I just rebuilt the carb on mine. I have the carter 1v on mine and the base gaskets that are in the kit are not correct, they are too large and caused a vacuum leak. Have the correct ones coming.
tr0y
Nov 10, 2014 07:02 AM
mikerans
Bronco II
Nov 17, 2012 09:31 AM
jmerrill89
Jun 20, 2011 03:16 PM
charlie2dogs
Jan 25, 2007 01:52 PM
chado
Dec 30, 2003 12:09 AM
