302 Timing chain/gears
Old Jan 31, 2010 | 04:33 AM
Bender99's Avatar
Bender99
I'm replacing the timing chain and gears in my 91 302 and wondering what year timing set to buy, I think I have read that with efi460's you can buy an earlier timing set and get a little more power out of it. Can you do it with 302's to get a little gain?
Old Jan 31, 2010 | 10:25 AM
BaronVonAutomatc's Avatar
BaronVonAutomatc
Year doesn't really matter as long as it's the right width. Comp and all the others sell timing sets that will let you advance or retard cam timing.
Old Jan 31, 2010 | 03:46 PM
Bender99's Avatar
Bender99
Where's should I buy the set from for a good quality set?
Old Jan 31, 2010 | 06:49 PM
fordeverpower's Avatar
fordeverpower
doesn't matter where cause its most likely a cloyes, or federal mogul, melling blah blah chain.
The factory has some motors with retarded centerlines, mainly in the mid 70's. Like mentioned if you get a decent aftermarket chain or one with advance or retard keyways. You will be fine, depends on cam and use also.
Old Jan 31, 2010 | 11:10 PM
Bender99's Avatar
Bender99
It's just a stock fuel injected motor
emmakk
1978 - 1996 Big Bronco
20
Jan 15, 2012 01:47 AM
restoringmy46
Mar 16, 2009 12:33 PM
John with beastly 302
27
Nov 14, 2008 11:09 AM
chrono4
Jan 26, 2005 09:51 PM
Kent Wales
Sep 1, 1999 08:02 PM
