converting front end
Old Aug 28, 1999 | 09:32 PM
cory's Avatar
cory
I have a 1976 ford truck and was wanting to convert the front end to a tilt. Has anyone ever done this? I want to do the work myself, any books,info, hints, thoughts, ect? Thanks for any info. Cory
Old Aug 28, 1999 | 10:14 PM
jowilker's Avatar
jowilker
Cory, call Tom at Carolina Classics 919-682-4211. He has done a couple of these, I think that they are called BMW kits or something like that.
Good luck,
John
Old Aug 29, 1999 | 07:32 PM
Like M. Fords's Avatar
Like M. Fords
Not sure of what you mean by a front end tilt, are you talking about the front axle? I know of a few companies that sell 2, 4, and 6 degree C-bushing kits for F150's and Bronco lifted applications. They tilt the axle to correct for the change that occurs when higher lift front coils are installed; an inexpensive and easy, but effective alternative to lowering the rear of the radius arms. These are quite common now and most parts stores carry them, however they should have been included with your lift kit unless you bought your springs seperate or swapped them from another vehicle.
Old Aug 30, 1999 | 06:48 PM
cory's Avatar
cory
No,instead of only lifting my hood open I want to be able to make it so everythig lifts open,fender,hood (Like a semi does).Thanks though.
Old Aug 30, 1999 | 08:27 PM
slik's Avatar
slik
cory5517
13
Aug 13, 2013 03:23 PM
corys4646
1997 - 2003 F150
Nov 30, 2011 05:52 PM
cpickner
Sep 21, 2011 11:42 AM
Ziggy.
Tennessee Chapter
Feb 15, 2009 08:54 PM
18cory
Sep 22, 2001 10:25 PM
